Weathering panzer grey
    December 2005
Posted by Stuart06 on Tuesday, December 10, 2019 7:57 AM
I have a stug iii that is painted panzer grey,  there is some highlights of lighter greyish blue on the model as well.
I want to weather this so that it looks like it would in Poland 1939 or France 1940, but due to the dark color of the panzer grey, I am wondering what colors should be used.
The model is painted in acrylics with a protective gloss coat so that I can apply the weathering with oils.....
Most of my friends are imaginary
Sell your watch, because time is money $$
In Canada hwy speed is measured by number of moose tracks per hockey goal.
Posted by Tojo72 on Tuesday, December 10, 2019 8:55 AM
Weathering has nothing to do with the color of the tank,it is the environment you want to depict it in.If you really want to be accurate,you would need pigments to dust the vehicle especially the tracks and running gear.If you want mud then make that using the appropiate pigments,but if your not overly concerned,any dust,dirt,or mud pigment will do.Mig Productions makes a nice range.
You can also make a dust wash,or use a pre mixed one.
If you are making an oil wash,its the same thing,light dust,dark dust,Russian earth industrial dirt,sand,whatever environment you want your tank in.
Posted by gregbale on Tuesday, December 10, 2019 9:04 AM
Dry-brushing over the whole surface with a slightly-lightened tone of the base color is never a bad place to start. It simulates the 'scatter effect' of real light on a large surface -- basically breaking up the monotone blocks of color that your eyes never see as such in real life.
For weathering and wear, more lightened and more concentrated dry-brushing can then be applied to edges and raised detail. Then would come the mud and dust effects that Tojo spoke of.
Good luck.
Greg
George Lewis:
    May 2017
Posted by Frankenpanzer on Tuesday, December 10, 2019 12:32 PM
This is roughly 5 different shades of gray tied together by weathering. I modulated the base colors by going dark on the lower part of the hull and places  where shadows would normally occur. It looked like a circus wagon until I used washes and pigments to dirty it up.
Posted by Bish on Tuesday, December 10, 2019 2:37 PM
Dry brushing, streaking, some dust effects and pigments. As mentioned, the colour doesn't matter on the methods you use.
Modulation is a purely artistic effect if you want to go that route, but i prefer to keep it realistic.
    July 2004
Posted by stikpusher on Tuesday, December 10, 2019 6:27 PM
Unless you go really light on dust coats and weathering like mud, etc., the fuss over the base color goes right out the window...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2015
Posted by M. Brindos on Tuesday, December 10, 2019 8:23 PM
If you're going for light weathering then modulation can still be something to try. I like to keep a balance of light modulation and weathering. But I've yet to complete a proper base for any of my models.
Modulation, if kept to a minimum can still help the overall finish and presentation. Works best with solid colors to break up an otherwise monotonous overall color tone.
With camo patterns it doesn't always work very well. So trust you're weathering to bring out the details.
 Examples;
Camouflage with no weathering (simple wash)
Vs.
Overall color with mild weathering and light modulation
It all depends on the look you're after.
- Mike Brindos "Lost Boy"
