New to modeling (Ryefield Models Puma IFV)
    January 2020
Posted by BusterBunker on Monday, January 20, 2020 5:06 PM
Hello everybody! This my Puma IFV I just completed. I had a few plastic snap together models about 20 years ago when I was really young, but this is my first real model I have ever attempted. My patience was definitely tested between assembly, learning how to airbrush, and weathering.
I made lots of mistakes and I was about to throw it against the wall a few times lol. My biggest mistake was building and completing the tracks but glueing the top of the hull to the bottom of the hull before attaching the tracks. However, in the end, since you do not see the top of the tracks anyway, I was able to remove about half of the tracks and manually feed them around the drive sprockets, road wheels, and Idlers.
Folding some of the photoetched parts was a pain in the rear end. I broke the main mirrors off multiple times and ended up just glueing them in the down position.
I bought an Iwata HP-CS airbrush along with a little Harbor Freight air compressor and learned how to spray acrylics on the fly. I somewhat followed the Nato camo scheme on it and used Vallejo acrylics. I am actually very pleased with the paint job. Painting many of the clear parts was a problem because I glued them on during building. I will wait after I have completed my next model to attached most of the clear parts. Other than losing one decal the rest turned out great. I used Mission Models gloss and flat coats to seal the model.
I used some acrylic thinner and Vallejo pigments to weather the tracks and model. My first weathering attempt was way overdone. It dried looking like it came out of a sand storm. So I washed off all the weathering and toned it down a lot.
I love IFVs and I really like the Puma so now I have my own model. I am thinking about doing the Meng Bradley Busk III next. Tips and tricks are appreciated.
Posted by Tojo72 on Thursday, January 23, 2020 3:44 PM
Very nice job,first kits are tough,it will get easier.Just so you know,I have left off the the top run of indie tracks if they are hidden just to make it easier on myself,it's all good.
    November 2008
Posted by mrmike on Thursday, January 23, 2020 3:54 PM
That turned out great! You choose a pretty complicated kit and finished it in style. For the TUSK, I would suggest taking a look at Academy's kit; it's an all new tooling that builds your choice of three versions and offers decent looking one piece tracks to simplify construction. I'm enjoying building it.
    January 2020
Posted by BusterBunker on Friday, January 24, 2020 1:10 AM
I actually just bought the Academy M1A2 Tusk II. I started building it today and it is going together like a dream. A lot easier than the Puma.
Posted by Gamera on Friday, January 24, 2020 11:42 AM
Oh that looks good! I too applaid you for tackling a complex paint scheme!
BTW can you tack cement the side skirts on? Aka you might try to cement them with just a little dab of cement and then paint. Once she's done pop them off, add the tracks and then cement them on securely. If you just use barely enough cement you should be able to get them off without messing anything up too badly.
    September 2006
Posted by RBaer on Friday, January 24, 2020 4:17 PM
Very good job, especially considering the complexity of that kit and it being your first. I think you'll find the Academy kit much easier to build, and it's actually a decent kit as well.
Apprentice rivet counter.
