Painting the RFM 1/35 Tiger 1 Late Production
    January 2020
Posted by Motley on Thursday, January 23, 2020 1:01 PM
Hello I am new to modeling tanks. I just started my first tank build Rye Field Models Tiger 1 Late Production. I'm doing the Normandy 1944 version.
I have some questions on painting it.
I watched some youtube vids on this tank and some people are painting these a bit different. Like the cables, tools, and other details. Are these details painted a different color? Or is the entire thing painted with camelflage?
Would the cables be rusted.
Also any tips for painting camelflage, I've never done this before. I have an air brush and I'm fairly experienced with that.
    June 2014
Posted by BrandonK on Thursday, January 23, 2020 2:47 PM
My understanding of German armor is that the tools were not painted with camo from the factory. BUT, that being said there were a lot, A LOT, of field applied camo that was done by the crew and they would slopp paint on whatever they like. So, to answer you question, they could have been either way. You would have to have a good photo of the piece you are building to argue one way or the other on THAT piece of armor. You really can't be wrong to do it either way. I prefer to paint them and leave the tools in a natural state, but that's just me. I like the detail it gives the eye. It's up to you.
Cables may have rust, but very very little and only is spotty bits, not overall. Most armor did not live long enough to rust up any or at all.
Camo paint is done in different ways by folks, mostly from preference. Paint the lighter colors first, then get darker from there. You can mask, use silly putty, or free hand camo. Again, it's your call. Experiment and find what you like.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Tojo72 on Thursday, January 23, 2020 3:39 PM
Artistic liscense,there are very few absolutes in WWII armor modeling.Just a light sheen of rust on cables,like from an overnight rain,because they were in use.Unless you are making a rusted out hulk.
    January 2020
Posted by Motley on Thursday, January 23, 2020 10:35 PM
Ok thanks very much for the info on this. I think I will paint the tools seperately, and put a tiny bit of rust on the cables.
Some thoughts so far about the kit. It doesn't come with zimmerit, but has a zimmerate application tool included. Why doesn't make sense, now I have to buy a zimmerit set on ebay.
The tracks. Oh boy I am not installing 200 peices of tracks together, way too much work. I will buy some metal assembled tracks I found on ebay.
There are a bit too many detail parts. Things like grab handles, could be modeled on making it look better then having to glue each one.
When I was at the hobby shop I saw the Tiger 1 with zimmerate by Dragon, and had assembled trucks, I should have got that one. Next build for sure.
    January 2020
Posted by Motley on Friday, January 24, 2020 10:45 AM
I gather they used the cables for towing other vehicels getting stuck in mud. Was there any other use for them?
Posted by Gamera on Friday, January 24, 2020 11:49 AM
As I understand the tanks were delivered from the factory in the mustard yellow scheme. Then the crew added the camo with an air-gun, brushes, mops, whatever they had handy. They probably didn't remove the tools to get a nice perfect paint scheme but I too generally leave them off, paint them, and then add them.
Zimmerit isn't that hard to make yourself. It does take some practice though. You can always get either a cheap kit or an old one to practice on. Or then again buying the PE zimmerit is an option too.
I have not build any Rye Field models, the separate grab handles look great but I agree with you- they're just too much Censored work. I'd never get them all straight.
As to the tow cables, I think you have it right there. I can't think of any other use. Hopefully someone with more information can chip in here.
Posted by Tojo72 on Friday, January 24, 2020 12:52 PM
Motley
A lot of us look for more detail,not molded on,and I don't mind assembling indie tracks and not adding a lot of cost to a build.
If your looking for good kits but a little lighter on detail,then you should go Tamiya.Dragon has a high parts count too.
    November 2004
Posted by snapdragonxxx on Friday, January 24, 2020 1:58 PM
The Tiger I seen in the Normandy campaign were usually SS heavy Tank companies. Only the elite got to use these and the Tiger II.
They were delivered to the unit in a base coat, for the Normandy Campaign, this was the base coat
Using this, RAL 6003 and RAL 8017 were used as disruptive patterns and were applied in the field by the maintainance company/tank crew to suit local conditions, which is why you never see the same pattern on a tank, unless it was factory done.
Usually the tools were taken off the tank for painting to be done and nets and tree branches also used to break up the lines of vehicles to hide from roving allied tank busters.
At this moment in the modelling world RAL 7028 and its variants in chipset correct colours are rare (AK's range is wildly out apart from one which is close enouogh to be used) and actually the closest shades which will pass when the green and chocolate brown are applied are Vallejo's Afrika Corps colours found in their Model Air range.
Posted by Bish on Friday, January 24, 2020 2:53 PM
being new to armour building you have certainly jumped in at the deep end. many of the new range of kits are higly detailed with high parts count. And i certainly would not recomend a Dragon kit, those can frustrate even the most experianced model builder.
As mentioned above, German armour at this period was delivered in the dark yellow, the green and re/brown were applied by the troops in the field. It would be up to them if they removed the tools or just painted over them. Personally, i like to paint the tools seperatly as this adds some variantion.
On a Tiger, there are 2 types of metal cable. The 2 thicker ones on the hull roof are for towing, though it was forbibben for a Tiger to reciver another vehilce, but of course it did happen. The longer thinner cable on the right side is used for fitting the tracks. This is a Dragon kit i finished a few weeks ago, you can see the thicker cables on the hull and the thin one in use.
The pre zimmed kits are nice and it makes it easier, but i prefer to add my own with Miliput as it looks more realistic and you can add damage as well as fit tool clamps and other items properly.
    January 2020
Posted by Motley on Saturday, January 25, 2020 1:37 PM
Wow lots of great info here on the Tigers, I appreciate it.
I had no idea I was jumping in the deep end. I was at the hobby shop and just picked a cool looking kit. LOL
I have made it to the turret completion, and so far so good I have not screwed anything up. Should I paint the inside of the turret? Or don't bother.
Been watching a lot of youtube vids, and will be picking up some books on armor modeling.
I will stay away from the Dragon kits for now and will get a Tamiya kit. Maybe the 38t? Would that be a good one for me.
Posted by Tojo72 on Saturday, January 25, 2020 2:01 PM
Motley
I enjoyed it,very simple build,one color.
Posted by Gamera on Saturday, January 25, 2020 2:34 PM
Bish and Snapdragon are the experts here on German subjects and Tojo and Brandon are fantastic modelers so if they say so it's gotta be!
If you're going to seal the Tiger up I wouldn't worry about painting anything in the interior. If you're going to stick a commander in the turret hatch you might want to paint what you can see.
I have to concer, Tamiya kits are pretty simple to assemble and look great. Academy is usually pretty good too.
In any case please post her when done, I'd love to see her!
Posted by Tojo72 on Monday, January 27, 2020 11:39 AM
Motley
This guys building one,follow along
http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=282873
    January 2020
Posted by Motley on Tuesday, January 28, 2020 3:24 PM
Well Im having a problem with the wheels. The large wheel on the front with the sprocket, doesn't even attach properly. I'm having to use some soda cans on both sides because they are floppy and loose. Dumb design.
Another complaint is the instuctions. Each step has like 100 parts and doesn't clearly show exactly how they attach. Just shows lines/arrows from a hundred different directions. And no pics of parts should be attached, unless I look at some of the next steps.
Will not be buying RFM or Dragon kits again.
    April 2013
Posted by KnightTemplar5150 on Tuesday, January 28, 2020 4:40 PM
Hard to tell in the pic, but did you glue the transmission drive housings on the axle of a suspension arm?
    January 2020
Posted by Motley on Tuesday, January 28, 2020 5:02 PM
Yes I did indeed glue the transmission drive housings to the axles, exactly how the instructions say.
Another comlaint is having to drilll all kinds of holes everywhere. How can this be fun, and why these companies design kits like this, is beyond me.
    April 2013
Posted by KnightTemplar5150 on Tuesday, January 28, 2020 6:24 PM
Normally, the final drive housing is mounted flush to the sides of the hull forward of the axles for the first station of roadwheels. Most companies have a circular recess to indicate where the drive housing gets seated.
Just a heads up - the Academy Tigers use the same system.
    May 2017
Posted by Frankenpanzer on Tuesday, January 28, 2020 8:21 PM
Your drive housings are mounted incorrectly. They do NOT attach to swing arms. They should be attached to the hull sides at the very front. Here's a shot of the real thing.
    January 2020
Posted by Motley on Tuesday, January 28, 2020 8:30 PM
KnightTemplar5150
Oh dang. Ok how about the Tamiya Tiger 1.
And will probably pickup the Taminya 38t as well.
    April 2013
Posted by KnightTemplar5150 on Tuesday, January 28, 2020 10:47 PM
Tamiya's design is pretty much identical in how it goes together. Academy, Rye Field, Dragon, and several other companies all do the suspensions of Tigers the exact same way. The design is almost an industry standard, so expect to see very little variation.
They all suffer from the same sorts of shortcomings as you have listed - the interleaved suspension can be a pain to line up, every company has you drill out holes to suit different build options and personal tastes, every one of them has instruction sheets that can be difficult to follow sometimes, and most require a extra little work if you want to incorporate zimmerit into the build.
It's the nature of the beast.
    January 2020
Posted by Motley on Tuesday, January 28, 2020 11:40 PM
Frankenpanzer
Wait what? Totally confused. The directions say the drive housings go into wheel, then to axel. The hole on the drive housing is too big for the axle ends, and its loose.
    January 2020
Posted by Motley on Tuesday, January 28, 2020 11:48 PM
KnightTemplar5150
Oh boy this not very encouraging.
    April 2013
Posted by KnightTemplar5150 on Wednesday, January 29, 2020 1:03 AM
Motley
Frankenpanzer
In your top photo, you have a completed final drive assembly with the sprocket wheel already mounted sitting off the model.
Step 9 of the instruction sheet shows this assembly being mounted directly to the hull, not on an axle. In the illustration, there is already a road wheel mounted onto the first axle. The position for your drive assembly is a large recess created when you joined parts P22 and P23 to the hull in step 8. It's circular in shape, but keyed to your final drive assembly so that it only fits one way.
Take the housing off the one axle and install both per the directions and you're back on track, so to speak.
    January 2020
Posted by Motley on Wednesday, January 29, 2020 6:02 AM
KnightTemplar5150
 Frankenpanzer
Holy crap that was it.! Got it in the corect place now. I don't know why, but lets chalk it up to newbie modler. Learned something today.
Thanks for the help.
Still not looking forward to drilling thousands of holes. Will probably put this kit on the shelf until I get better with all this.
Gonna try the acadamy kit.
    May 2017
Posted by Frankenpanzer on Wednesday, January 29, 2020 8:34 AM
I was going to say, there's an indentation in the front of the hull that the drive housing fits into.
    January 2020
Posted by Motley on Wednesday, January 29, 2020 10:57 AM
Frankenpanzer
And it doesn't help that I know very little about tanks and their parts. I need to get some books.
So this drive housing would be similar to a differentlal on a car, or more like a transmission?
    May 2017
Posted by Frankenpanzer on Thursday, January 30, 2020 12:23 AM
The transmission is internally mounted. The drive housing is like a differential. There are great big drum style brakes just inside the hull behind the drive housing. They are used to steer the tank by slowing the drive of one track or the other. The Tiger had a steering wheel to simplify the task. Most tanks just had two levers to control the brakes. The Tiger had the levers as backup as the steering system was, like the whole tank, overly complicated.
    September 2005
Posted by warshipguy on Friday, January 31, 2020 10:10 AM
Motley,
There is a wonderful YouTube channel called Andy's Hobby Headquarters that has many instructional videos about building, painting, and weathering tank models, including one on the RFM Tiger I.  I recommend it highly, especially for those who are inexperienced builders.  Check it out.
Bill'
    January 2020
Posted by Motley on Friday, January 31, 2020 11:06 AM
warshipguy
Motley,
Bill'
Hi Bill,
I did in fact see some videos on Andys Hobby Headquarters. Yes there are some good tank build videos there. I just recently watched the video for RFM Tiger. But he makes it look so easy. LOL
Michael
    September 2005
Posted by warshipguy on Friday, January 31, 2020 12:34 PM
Michael,
He does indeed.  However, he criticises companies like RFM for making models much too complicated. He acknowledges that most builders would rather build a kit of 200 parts rather than one of 2000.
I like his videos, although I have been building models for over 60 years. They are very informative, they allow me to see new kits before I buy them, and I like his painting/weathering techniques.
Good luck with your Tiger I.  I strongly recommend Tamiya or Academy kits as very enjoyable kits to build.
Bill
