Tamiya 1:35 M3 Lee Rubber Band Tracks Replacement
    November 2014
Posted by AceVonScooter on Thursday, February 27, 2020 9:38 AM
I'm most complete on this model and really like the way it is turning out but I hate the rubber band tracks.  I've looked for workable tracks to replace them but am uncertain which type to buy as I see T-16, T-41, T-48 et.al.  I'm intend to build it as one of the two versions offered in the box operating out of Tunisia in 1942 timeframe.
Can someone assist me in selecting the right model of tank track to use for this model?  If you have a recommendation on the brand, I'd appreciate that as well.
Thanks!
Posted by Rob Gronovius on Friday, February 28, 2020 12:22 AM
T51 tracks would be the proper ones, but I seem to recall that there might be an issue with the track pitch due to the odd sprocket, but it's been a while since I've dealt with that kit so I don't remember all the ins and outs.
    November 2014
Posted by AceVonScooter on Saturday, February 29, 2020 11:30 AM
Thank you.  I've ordered a set.  Of course the tracks cost almost as much as the model!
I hope you'll pardon one last question... how did you know this information?
Tags: Tamiya , 1:35 , Lee , m3 , Tank Tracks
Posted by Rob Gronovius on Saturday, February 29, 2020 11:38 AM
Sherman Minutia is a good source of information, but just look at what comes with more current M3 Lee kits, like the Academy, Meng or Takom kits to see what the "proper" type tracks would be.
http://the.shadock.free.fr/sherman_minutia/tracks/vvss_tracks.html
    November 2014
Posted by AceVonScooter on Sunday, April 5, 2020 10:45 AM
I wanted to follow up.
First, the Sherman Minutia sight was fantastic.  Thank you Rob Gronovius!
Second, a lesson learned for others.
I purchased and built AFV's T51 workable track lengths.  However, these tracks will NOT work for the Tamiya M3 Lee tank.  (I knew from research that there might be a problem so I went into this with my eyes wide open.)
There are two problems.  The drive sprocket has a shoulder that prevents the track teeth from completely seating in the sprocket.  I tried to overcome this by grinding the track teeth (only those that contact the sprocket) to reduce their height.  Then I discovered the real problem... the distance between the drive sprocket teeth is not the same as the distance between the track teeth... so even after grinding down the track teeth height in the vicinity of the drive sprocket, the tracks will never seat properly around the sprockets.
I've saved the AFV tracks for use on a future model and used the OEM rubber band tracks that came with the model.
    July 2004
Posted by stikpusher on Sunday, April 5, 2020 11:00 AM
You may want to look at some replacement sprockets. Many Sherman kits come with optional sprocket types, and those are the same as used by the M3 Medium family as well. If you have more than one Sherman your stash, or a spares bin/box with some from previous builds, have a look, your solution could be in there.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Rob Gronovius on Sunday, April 5, 2020 12:47 PM
I didn't want to discourage you, but putting good qualtiy aftermarket tracks on the old Tamiya kit is like putting DUBS on a Yugo.
    September 2005
Posted by richs26 on Monday, April 6, 2020 12:23 PM
Actually Rob, I think you miswrote your answer as it should be T-41 tracks as the original tracks for M-3's as the website states that T-41's were manufactured until March 1943, when T-51's were replacements.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
Posted by Rob Gronovius on Monday, April 6, 2020 12:51 PM
richs26
Doesn't matter since this is a day late and a dollar short and the kit isn't worth the dollar spent.
    July 2004
Posted by stikpusher on Monday, April 6, 2020 1:47 PM
Rob Gronovius
LMAO! But I’ll bet out there somewhere, there is a car club for Yugo enthusiasts, and amongst them, some tricked out Yugos... if the Pinto and Vega can have their fans...
       - Plankton
LSM
    September 2005
Posted by richs26 on Monday, April 6, 2020 2:10 PM
Yes, there are Yugo fanatics out there.
https://www.facebook.com/TheYugoClub/
Posted by CapnMac82 on Monday, April 6, 2020 7:47 PM
richs26
And even fans of the Trabant, which is some ways is a more successful import than the Yugo was Smile
Posted by Rob Gronovius on Wednesday, April 8, 2020 12:16 PM
The point I was making is that it seems like a waste to put high priced tracks onto a kit that isn't worth what the tracks cost. You could get a better version of the same subject for about the same amount of money as the tracks cost and would not need new tracks to begin with. Some of the better kits even include two styles of tracks; a set of vinyl and a set of link & length.
    November 2014
Posted by AceVonScooter on Thursday, April 9, 2020 9:50 AM
Thank you all for your input. The comments were right on the money. Normally I wouldn't consider spending the extra money on tracks for such a cheap model, but it came out better than expected and I had never tried workable tracks before so I thought it would be a good learning experience. And it was certainly a learning experience!
    September 2005
Posted by warshipguy on Thursday, April 9, 2020 6:13 PM
Do I hear a vote for the Gremlin?
Bill
