Muddy tank suspension....
    May 2020
Posted by gpat5570 on Monday, June 1, 2020 8:10 AM
Hi folks, many thanks for all the advice I have received here. Pratically new to scale modelling. At home for the time being, enjoybable hobby, something I used to do in my younger years...
Anyway, my question: what is the best method and material to use to obtain an 'earthy', muddy tank suspension? I am currently building a 1:35 CVR Scorpion. Rarely duing my years in the army did we have perfectly clean suspension on our vehicles!
Any tips, recommendations, etc. would be appreciated, thanks!
cheers
Garry
Posted by Bish on Monday, June 1, 2020 9:17 AM
I use pigments mixed with water and a small drop of washing up liquid. I just slap this all over, let dry and remove excess.
    June 2014
Posted by BrandonK on Monday, June 1, 2020 10:17 AM
Pigments work best, but powers can work also. In this case I would recommend Youtube for some ideas and application methods. Its fun to do and certainly makes the build better.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Rob Gronovius on Monday, June 1, 2020 11:25 AM
Posted by Gamera on Monday, June 1, 2020 11:32 AM
Pigments and powders are probably best. But I've had no luck with them. I picked up from Steve Zaloga adding a little 'stucco' paint (you can get at an art store) to the lower suspension. Then airbrushing Tamiya Deck Tan all over the lower sections of the vehicle and feathering it out as you go up. Then add a little Tamiya Dark Earth to the lowest sections of the vehicle. The Deck Tan looks like dried out mud and the Dark Earth like fresh wet mud. The 'stucco' gives it texture.
Recently I found that if you add a couple of coats of hairspray to the model before the mud coloured paint you can later stroke a moist wide brush down the model. It will cause some of the paint to come off giving a rain streaked appearence. It works with Tamiya paint in any case. Not sure it would with enamel or any other non-acrylic.
    November 2008
Posted by plasticjunkie on Monday, June 1, 2020 12:07 PM
All good methods listed above. You will have to experiment and see what works for you. I like using pigments mixed in rubbing alcohol cause it dries super fast and I can go back and remove the excess and even re use the pgments when depicting light weathering. Elmers glue works well too mixed with fine dirt and RR ground cover which looks good on the tracks for a heavier effect.  If using alcohol make sure the paint has cured as it may react with some uncured brands oterwise water and a couple of drops of Dawn will do fine.
These two were done with Alcohol and MMP Powders over cured enamel and excess removed with a brush once dry.
 GIFMaker.org_jy_Ayj_O
    May 2020
Posted by gpat5570 on Monday, June 1, 2020 1:01 PM
That's excellent, many thanks.
