You see thst seam between the upper and lower halves of the turret,that is where Tasca separates the two pieces of the turret.I'm just confirming,does that seam stay,or does it need to be sanded out
Referencing my hardbound book on the M4 the many pics I have do show a seam that you can see but has also been crudely "dressed" with a grinder, but remains visable.
Althought "Fury" is a movie, the tank was a legit E8 and in this pic you can see the seam well. Most of the pics in my books look similar to this. I hope this helps.
BK
On the bench:
A lot !! And I mean A LOT!!
14 / 5 / 2
The turret types were used on multiple versions. A 76mm T23 turret could be installed on any of the large hatch hulls, M4A1, M4A2, or M4A3, regardless of suspension type. The only change needing to be made would be the hull ammunition stowage. Here’s a good rundown with photos of the turret details
http://the.shadock.free.fr/sherman_minutia/turret_types/turret_types.html
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
Tojo72 You see thst seam between the upper and lower halves of the turret,that is where Tasca separates the two pieces of the turret.I'm just confirming,does that seam stay,or does it need to be sanded out
Scroll towards the bottom of this Sherman article and you can see the rough turret seam.
http://www.usarmymodels.com/ARTICLES/Sherman%20Corner/Turrets/shermanturrets.html
It's not actually a seam in the turret itself, it's a mold seam, from how the turret molds were made and the casting process. Different foundries did differing quality jobs and some left more excess material than others. Think of it as flash, just big scale.
Apprentice rivet counter.
