Dragon 1/35 Panther G
    February 2022
Posted by BattleTweety on Sunday, February 13, 2022 12:30 PM
This was an extremely enjoyable build and Dragon has produced a superb kit full of detail. They've labelled it a "Smart Kit" that's designed to be built OOB with no additional photo etch or after market parts. Not sure if thats a marketing gimmick, but I found the detail to be incredible and with over 650 parts I can attest to the sheer number of micro add ons.
The markings are for 11 Panzer "Ghost" Division stationed in Bavaria near the end of the war.
Paint used was Tamiya XF-60 Dark Yellow and XF-51 Khaki Drab.
Kit is highly recommended for lovers of the venerable Panther G.
cheers
BT
Tags: 1/35 , dragon , Panther G
On the neverending quest for the perfectly built model kit.
Posted by Gamera on Sunday, February 13, 2022 8:03 PM
Oh cool! Nice work!!!
650 parts sounds like a lot but I'm guessing two-thirds are the indy tracks?
    October 2021
Posted by PhoenixG on Tuesday, February 15, 2022 2:04 AM
Looks good!  Like how you did the wear and weathering.
On the Bench:
Bandai 1/72 Defender Destroid
    January 2015
Posted by M. Brindos on Tuesday, February 15, 2022 3:43 AM
One minor nit-pick. The tracks wouldn't have any visible rust on them. They were practically brand new at that time.
But that one minor complaint doesn't outweigh the absolute amazing job you did on this kit. Nor does it look any less than stellar to my eyes. That's one beautifully finished piece of armor.
The details pop, the camo is spot on, and the weathering is realistic.
Nicely done!
- Mike Brindos "Lost Boy"
    September 2005
Posted by warshipguy on Tuesday, February 15, 2022 8:58 AM
Well done!  I love the Panther.
Bill
    July 2015
Posted by MR TOM SCHRY on Tuesday, February 15, 2022 10:42 AM
Great looking Panther tank!  Super camo scheme and paint fading.
TJS
TJS
Posted by Rob Gronovius on Tuesday, February 15, 2022 12:04 PM
I think smart kits were designed to have better, easier fit and not be a nightmare like some of the earlier Dragon releases or ones that had multiple sprues from different kits, i.e. two Sprue "A" or "B" each from a different kit.
I think it looks good. The tracks could get rusty overnight and then get shiny spots where metal ground through gravel, rinse and repeat. I tend to leave my tracks shades of brown, earth, red brown etc.
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Tuesday, February 15, 2022 5:18 PM
Extremely nice with a great choice of colors.
The only nic I can find to pik is with the inner road wheels, rear idler and the front sprocket teeth.
                                                        http://www.millan.net/minimations/smileys/bokmal.gif
panther tank road wheel change
It might be the way the light is angled but I don't see any silver track wear pattern on the inner road wheel rims. As with all constant metal to metal contact there should be a similar wear pattern on the sprocket teeth and all around the edges of the rear idlers.
As for rust on tracks...  well, that can happen overnight ~ depending on the weather.
https://montecarloforum.com/forum/images/smilies/congrats.gifAgain, this is a very nice build.
 https://i.imgur.com/LjRRaV1.png
    February 2022
Posted by BattleTweety on Wednesday, February 16, 2022 11:47 AM
Thanks guys, all comments greatly appreciated. I'm still relatively new to building 1/35 armor kits. Interesting observation about the inner wheel rims. I hadn't seen that in any of the research I've done, but it makes sense once you mentioned it. I blame lack of WW2 colour photographs :). Defintely put some metallic weathering on the sprockets, probably doesnt show as well in my pictures.
cheers
BT
    June 2014
Posted by BrandonK on Wednesday, February 16, 2022 12:04 PM
Looks great, very nice work. Thanks for showing us.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    June 2003
Posted by Jammer on Wednesday, February 23, 2022 6:56 PM
disastermaster
I see this a lot when cleaning and seasoning cast iron; if you wash or rinse your unseasoned cast iron in warm water, it will flash rust almost immediately.
Posted by CapnMac82 on Friday, February 25, 2022 10:19 AM
disastermaster
Or not.  My Hitachi Excavator had steel tracks.  They "browned" after a couple of years, on the non-bearing surfaces, but no real rust.  At least nothing you could see at arm's length.
Flash rust was generally 'wiped off" in use.  Now, on the inside surface, where the rollers bear on them, there was a "buffed" area that was a deep metalic brown color.  Now, Hitachi uses steel rollers (pretty common for excavators) so that was steel-to-steel contact.  The guide horns on the track were a similar sort of finish.
The contact points on the drive sproket were "bright" but more of a gunmetal "white" finish trather than a "silver."
So, dunno, YMMV, maybe.
    March 2004
Posted by Mikeym_us on Tuesday, March 1, 2022 3:32 PM
Dragon still does that with their Smart kits I have the Imperial series Panther G command tank and it uses the antenna sprue found in their othe Panther G smart kits.
Rob Gronovius
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
