Tracked Gun Truck - 1:35 M548 with Quad .50
    May 2009
Posted by Pawel on Sunday, April 16, 2023 12:19 PM
Hello everybody!
I'll try to tackle this kit now:
1:35 AFV Club M548 with Quad .50 by Pawel
When I bought it there was just one photo of it availalble:
It's from the Concord's "Armor of the Vietnam War (1) Allied Forces" book.
Later veterans from the National Duster, Quad and Searchlight Association (NDQSA) came up with a photo of a similar but different vehicle:
Finally I have found (and this forum helped me with it) two more photos:
1:35 AFV Club M548 with Quad .50 by Pawel1:35 AFV Club M548 with Quad .50 by Pawel
And that did it - I thought: It's not going to get any better than that and I started working. Of course if you have any more cool photos, please post them in this thread. Also, if you have an idea what the "fine print" above the second road wheel in the photo above says - I would love to know it, too.
And I took the hull bottom out of the box:
And I decided to improve the wheel suspension - so that's what I'm working on now. Thanks for looking and have a nice day
Paweł
www.vietnam.net.pl
    April 2016
Posted by GlennH on Sunday, April 16, 2023 12:55 PM
I hope the quad 50 assembly is better than the AFC club gun truck I've had sitting for a year part built. I bought what I think are better 50's but the thing that's driving me nuts Pawel and has caused the pause is the gun mouting on both outside 50's. The inner mounts line up front and back but the outer mounts will *** the gun muzzle inward.
It suddenly dawned on me as I was typing this that that may be intentional to get the point of aim in the same direction. I had only seen one in the flesh from a distance. Pawel, you have built other quads, am I assuming correct? If so I still have to wonder why the outer mounting pads are not cocked slightly as well..
A number Army Viet Nam scans from hundreds yet to be done:
https://www.flickr.com/photos/southwestdreams/albums/72157621855914355
Have had the great fortune to be on every side of the howitzers.
Posted by Rob Gronovius on Sunday, April 16, 2023 12:59 PM
AFV Club does the mix and match form of kit creation. So this quad .50 is probably the same as the guntruck and towed version.
The National Guard still had the M42 Dusters in use as late as 1985.
I got a license to drive the M548 ammo carrier when I was a college kid, but that was the only time I ever had time on one.
Good luck with the project.
    December 2022
Posted by Tcoat on Sunday, April 16, 2023 2:12 PM
GlennH
Mine lined up perfectly.
To get the guns to coverge at any reasonable range you would hardly be able to see the angles.
    April 2016
Posted by GlennH on Sunday, April 16, 2023 2:55 PM
LOL I see by the three *** the four letter word I used for 'angle' was mistaken for an anatomical feature.
I see that and you're correct.. Yours is a different kit. On mine the front mounts on the outboard guns is probably 3/16 further inside than the back ones.
Posted by keavdog on Sunday, April 16, 2023 2:55 PM
Interesting subject Pawel.  I've never seen that vehicle before.
Thanks,
John
    May 2009
Posted by Pawel on Thursday, April 20, 2023 1:13 PM
Glenn - so far I've only built one quad 50 and it was by Dragon. The build report can be seen here:
http://vietnam.net.pl/M55mod1en.htm
Like Tcoat wrote, the barrels would have to be practically parallel. Now that AFV Club quad is somewhat old and has a lot of misunderstandings, but is still a step up from the gun truck "Nancy", because you get a resin trailer chassis that is correct for all quad 50s in Vietnam. Some parts in the kit, however come from the half track M16 version - you have to watch for those when building this kit. The power charger (small gas engine/generator) would have to be replaced with something newer here.
Rob - That's interesting! So what do you reckon, how many hours do you have in one of these babies? Like I wrote above, this kit has a substantial commonality with "Nancy" gun truck, but improves on it.
Tcoat - maybe I'll get to building a gun truck on wheels some day too...
John - a plain M548 seems to be a pretty common vehicle, but it has some wild variants, too, and those can be rare.
Thanks a lot for your comments and have a nice day!
Paweł
www.vietnam.net.pl
    April 2016
Posted by GlennH on Thursday, April 20, 2023 4:49 PM
Pawel I just looked at your quad build again and posted a question you have already solved somehow. How did you make the bends on those ammo belts? They turned out fantastic and no doubt you'll be doing it again.
THese must be out of this world I bet.
https://www.hlj.com/1-35-scale-flexible-ammo-belt-cal-050-gas35150
Pawel
Paweł
Posted by Rob Gronovius on Friday, April 21, 2023 12:18 AM
Pawel
The M548 was just basically an armored pickup truck. We had ring mounts on some of them, but I don't recall ever seeing an M2 mounted. The cab cover was always in place.
We learned to drive on M113s and the M548 drove the same way. Easy to drive, at most I probably was on one for a couple of days worth of training.
    May 2009
Posted by Pawel on Sunday, April 23, 2023 4:44 PM
Hello everybody!
Glenn - I already wrote you something in the thread you started! Thanks a lot for your kind words!
Rob - you make it sound like fun!
And in the meantime I got an Italeri M113 variant to use it as a donor for a chassis parts transplantation. I started with lots of dry fitting and measuring. Then I drilled a hole in each road wheel pivot point to mark their positions. At last I took a saw and levelled the playing field, so to say:
As you can see I have already made some road wheels. The leftmost wheel shows the AFV Club part - as you can see no detail on the inside, whatsoever. That's why I decided to take the italeri part for the inside of the road wheel (second from the left), but also use the AFV Club part for the outside (it's quite nice).
As I'm writing this I already glued the road wheel arms in place and now I want everything to dry throughly to get a nice stable alignment. Then I'll take next photo for you and start working the other side.
Paweł
www.vietnam.net.pl
Posted by HeavyArty on Monday, April 24, 2023 8:43 AM
Nice job.  It is coming along well and the updated suspension and roadwheels will make it look great.
Posted by Gamera on Monday, April 24, 2023 8:21 PM
Oh wow, that's so cool Pawel! You always find the coolest subjects!
    May 2009
Posted by Pawel on Thursday, April 27, 2023 7:03 PM
Hello!
Gino, Gamera - thanks a lot for your comments, I'm glad to have you on my thread here!
Gamera - you bet I put a lot of time and effort to select the right ones! Stick out tongue
And I also wanted to let you know how the "transplant" is doing. Here's how the new suspension looks from the inside:
And here's a photo showing the wheels off, a the same time comparison to stock suspension on the other side:
And it's that other side that I'm working on right now... I could use some "The Doors" right now... "...break on through to the other side, break on through to the other side, yeah..."
Thanks for looking and have a nice day!
Paweł
www.vietnam.net.pl
Posted by Gamera on Friday, April 28, 2023 7:37 PM
Looks good Pawel, great improvement to the original kit.
    August 2021
Posted by lurch on Saturday, April 29, 2023 3:41 AM
Thats looking fanrastic. Like Gamera said earlier, You always pick great subjects. I always enjoy your work, And you always do fantastic work. Thank you.
    May 2009
Posted by Pawel on Tuesday, May 2, 2023 4:11 PM
Hello!
Gamera - thanks a lot!
lurch - thanks a lot for your kind words, they mean a lot to me!
And I managed to finish the transplant! As it turns out, Italeri gives you 69 track links per side, which looks like a lot, but the tracks are still two links too short - so I decided to scratchbuild those missing two links per side and put thm where they will not be too visible. And so the tracks are finished:
As I still want to paint them, I just made the track sets removable for now - that should help with said painting:
Now I'm starting working on the hull - I have to distress the sheet metal some, to match the 1:1 photos.
Paweł
www.vietnam.net.pl
Posted by HeavyArty on Tuesday, May 2, 2023 5:05 PM
Looking good.  It is interesting that there were too few tracks.  I built the Italeri M901 years ago and it had the correct number of tracks.
Posted by CapnMac82 on Wednesday, May 3, 2023 12:38 PM
Is it me, or amybe photo distortion that makes the drive & idler looks just a smidge too far forward & back?
Like, maybe the donor kist locations were a tad long?
Would that be worth taking calipers to other 113 kits to measure the center-to-center, maybe?
This, as it's all too common to take measurements off unloaded museum/display vehicles, which is like to make the resulting track length too long, rather than too short.  Just spitballing here, but also remembering one too many high-riding M-60 kits.
Posted by Rob Gronovius on Wednesday, May 3, 2023 6:35 PM
Many display tanks and APCs have tracks that have worn rubber bushings that make the tracks seem much more loose than they would be on a vehicle in service. Walking track is a weekly and sometimes daily task done by crews, so any track links with worn bushings would be replaced more frequently.
In a tank battalion, just about every tank had track changed out annually, not as a scheduled event, but as it was needed due to wear and tear after major exercises.
    May 2009
Posted by Pawel on Thursday, May 4, 2023 2:40 PM
Hello!
Thanks a lot for your comments!
I don't know exactly why it turned out this way, but I think there's some problem with the Italeri track to begin with - there are 69 links per side in the box, AFV Database says there should be 63 on the left and 64 on the right - that's one thing. Then I agree with Cap'n - it would be enough that the distance between the sprocket and the idler is 4mm bigger than in the M113 kit and there you have your 2 links.
I have no way of knowing for sure, but for me the photos of the real thing show the track in pretty good condition and not too loose - but a bit on the loose side, as it seems to touch the rear road wheels. I remember reading that the correctly tensioned track should hang a bit above one of the road wheels - but I don't remember how much and above which wheel it should be.
I also managed to decipher the inscription behind the driver's doors - it seems to read: "REMOVE SCREEN, INSTALL DRAIN PLUGS,
ACCESS COVER PLATE AND GASKETS,
BEFORE VEHICLE OPERATION"
Now I wonder what could be meant with "screen"?
So now I'm startin to work on custom decals, as I need some data placards for the interior.
Thanks for reading and have a nice day!
Paweł
www.vietnam.net.pl
    June 2004
Posted by TigerII on Thursday, May 4, 2023 5:35 PM
Hey Pawel, nice work on the tracks. I like the subject you've chosen. I see that the suspension is like the USA M113 APC. In the photo of the front, it resembled the Marine Corps LVTP-7 Amtrac. Anyway I'll be keeping tabs on this build. It looks good so far. Good luck.
Achtung Panzer! Colonel General Heinz Guderian
Posted by HeavyArty on Friday, May 5, 2023 9:12 AM
TigerII
It is an M113 suspension.  The M548 is a modified M113 with the hull cut away and reconfigured in the front to be a cargo vehicle as opposed to an APC.  The engine, running gear, and lower hull are all the same as an M113.
Posted by CapnMac82 on Friday, May 5, 2023 11:35 AM
Wow, I had clean forgotten that the tracks were a link different from each other--memory wants to put that down to the "stagger" in the torsion bars, that one on one side is ahead of the other.
Posted by Gamera on Monday, May 8, 2023 7:15 PM
That's funny about the missing links there but great job fixing the issue!
    May 2009
Posted by Pawel on Monday, July 3, 2023 2:42 PM
Hello everybody!
I sure did hope I could post an update here sooner... But, like they say - better late than never! The thing is the interior of the AFV Club kit is pretty barren, and without the windshield and roof it will be very visible... Eduard set 35906 helps a little, but I also had to design my own decals, then get them printed - but finally I can show you my results.
So here are some details and first decals on:
And here are the interior parts painted up and more decals... I have also made the fire extinguisher. There will also be a 3D printed flashlight, and I think I have to 3D print the fire extinguishers, too, for future projects.
Here's a link to the 3D prints in case somebody could use them:
https://www.shapeways.com/shops/nam-models?section=1%3A35&s=0
So, how do you like my data plates?
Thanks for lookin' and have a nice day
Paweł
www.vietnam.net.pl
    May 2009
Posted by Pawel on Thursday, July 13, 2023 6:31 PM
Hello!
So here's another update on this one...
I have built a first aid kit and a flashlight (it's 3D printed), here's what they look like in big magnification:
In case anybody needs a flashligh like this it can be had here:
https://www.shapeways.com/product/8QYFT3D3D/1-35-mx-991-u-flashlight-16x
And the cockpit looks like this so far:
I have also dry fitted the tailgate and the cargo door:
The blue arrows point to the hinges I made to replace the kit hinges that would allow to make the tailgate "operational" (what for?), but they were decidedly oversize... The yellow areas mark the tailgate latches missing altogether, and the red areas mark the cargo door latches that would have to be removed and re-done... So that's what I'm working on right now.
Paweł
www.vietnam.net.pl
Posted by HeavyArty on Thursday, July 13, 2023 7:06 PM
Its coming along nicely.  Excellent on the small details.
Posted by Gamera on Thursday, July 13, 2023 8:21 PM
She's coming along great Pawel, love all those little details!
    May 2009
Posted by Pawel on Saturday, July 15, 2023 2:43 PM
Gino, Gamera - thanks for sticking with me on this one! I'm glad you like the details, in this case I'll add some more! :-)
I'll try to post some update soon - have a nice day!
Paweł
www.vietnam.net.pl
Posted by Rob Gronovius on Saturday, July 15, 2023 7:44 PM
If I remember, that tailgate could fold down like a traditional truck tailgate or could open to the right or to the left like an actual door. These things used to be loaded with so much stuff it was unreal.
