Correct Olive drab for USA armour?
    May 2011
Posted by dazzjazz on Sunday, April 30, 2023 3:26 AM
Hi,
I'm building Tamiya's M18 Hellcat and would like to get the paint job just right.
I have Tamiya's acrylic Olive Drab, which looks pretty good, and MIG/Ammo Olive Drab base, which seems too brown to me.
So, which should I use? I'm happy to buy another as long as it's acrylic.
thanks
Darren
Posted by Tojo72 on Sunday, April 30, 2023 6:17 AM
Lotsa discussion on this,come to your own conclusion of what looks good to you,like Dunkelgelb,4BO,or Panzer Gray very subjective.
Here's an article with some thoughts,check yourself for others,there are many on the net.
https://www.britmodeller.com/forums/index.php?/topic/235110522-current-thinking-on-tamiya-xf-62-olive-drab-for-us-m4-1944-45-eto/
    October 2019
Posted by Tanker-Builder on Sunday, April 30, 2023 6:52 AM
Hi Darren!
     I have always used a basic O.D. then Wash it with a wee bit of light tan. This is more wash than color. O.D. had a tendency to turn dusty looking in exposure to sunlight. I just recently turned to acrylics so I  cannot speak to that. It should work though.
    August 2005
Posted by EdGrune on Sunday, April 30, 2023 11:02 AM
Air OD was different from armor OD, and each could vary by the war production plant, period of the war, and even day of the week.   A new, shiny tank exiting the production line may look different after its rail trip to the port of embarkation and the voyage across the ocean.    Heaven forbid you add field maintenance to the mix.
Find a paint which you prefer and go with that.   As a modeling mentor of mine once said, 'When the pigment hits the plastic, its right".
Posted by Rob Gronovius on Sunday, April 30, 2023 11:39 AM
dazzjazz
Hi,
thanks
Darren
Best of luck to you; this question is often asked, discussed and open to debate.
It's like, "What color is the sky?" or "How long is a piece of string?"
I'm okay with grabbing any old can of OD green and using it. I spent a long time in the Army and the color green we used varied considerably, even among new items.
    September 2005
Posted by richs26 on Sunday, April 30, 2023 5:43 PM
Here is an article by "Mr. Armor", Steven Zaloga, on WW2 Armor and Munitions OD and the difference between AGF OD and USAAC/AF OD-41:
Zaloga - Olive Drab.pdf
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    May 2011
Posted by dazzjazz on Monday, May 1, 2023 4:07 AM
Thanks for all the input evertone, I will check out the links.
    May 2004
Posted by cbaltrin on Monday, May 1, 2023 7:19 AM
And don't forget to match the paint to the color temperature of the light the model will be viewed in and set you white-balance correctly if you take any picturesWink
On the Bench: Too Much
    September 2006
Posted by the Baron on Monday, May 1, 2023 11:43 AM
dazzjazz
...I have Tamiya's acrylic Olive Drab, which looks pretty good...
That's what I would go with.  If it looks right to your eye, then forget what anyone else says.
Posted by CapnMac82 on Monday, May 1, 2023 12:25 PM
Am I remembering rightly, that the Hellcat survived into the DOD era (post '47)?
WHih introduces yet another "OD" into the mix.
