1/35 Tamiya Panther Ausf. D, 4th Company, 51st Panzer Battalion, 39th Panzer Regiment, Kursk, July 1943. (Complete)
    July 2019
Posted by Hoss WA on Tuesday, July 25, 2023 7:52 PM
This model represents Panzer No. 432, 4th Company, 51st Panzer Battalion, 39th Panzer Regiment, Kursk, July 1943. This Panther was produced at the Henschel factory in May 1943.
Here's a summary of additions and modifications:
  • Scratch built commander's cupola interior and using vision blocks from Panzer Art resin upgrade set
  • Scratch built weld seams
  • Panzer Art antenna
  • Wire for forward hatch handles and engine access door hatch handles
  • Eureka tow and track change cables
  • Rochm Photoetch upgrade kit for retaining chains (with wire pins) on spare track and C hook brackets
  • Tamiya "Detail Up" photoetch screens for engine deck grills
  • Tamiya individual link track upgrade set
  • Aber armament set for main gun barrel, muzzle brake, and coaxial machine gun
  • Eduard vehicle clamps (3d printed)
  • Various bolt heads on equipment and spare track brackets
  • Aber side skirts
  • Aber smoke grenade launcher upgrades
  • Fine molds fender poles with brass tubing mounting bases
  • Zavod detail kit (3d printed) for spare track brackets
AK Real Color lacquer was used for the RAL 8012 primer, applied for chipping effect. Tamiya acrylics were used for the main camo. Tamiya and Vallejo acrylics were used for detail painting. Abteilung oils and AK enamels were used for weathering. Kit decals were used for all markings.
Dirt and dust effects were applied using Abteilung 502 oil paints.
After the oil paint was dry, a flat coat using Mr. Color GX 114 was applied.
Engine oil and fuel stains were applied using enamel grease and grime effects.
Mud effects were then applied on the lower hull and wheels using enamel washes and pigments to build up the desired effect. I’m happy with the wheels as well as the lower front and rear hull sections.
Here was my process for painting and weathering the tracks. I didn’t want to use a lot of enamels since they’re relatively delicate.
1. Gray Primer
2. Tamiya XF-24 dark gray
3. Vallejo model wash black
4. Dusting layer of Tamiya XF-57 light and random sections
5.Vallejo model wash brown
6. Speckling using splash effect
7. Thinned XF-85 rubber black lines where tires ride on tracks
7. Drybrushed metal sections – guide horns, edges, ground contact surfaces
8. Integrate with wheels and hull
My installation sequence for the running gear started with the wheels. The tracks were then fed through the sprocket wheels and the end links snapped together easily. Finally, the side skirts were mounted to their brackets, which were tightened firmly to hold the skirt sections in place. The lower sections of the skirts needed some additional dust weathering with oils after installation to be consistent with the rest of the tank.
Finally, the antenna and fender poles were installed, followed by some graphite pencil application on key metallic surfaces.
The two crew figures were painted with Vallejo acrylics.
My final thoughts are that it was a good fit and straightforward build. However, it took quite a bit of extra spend and work to get the details to where I was satisfied. I’m happy with how it finally turned out.
I will most likely turn to Dragon, Cyber Hobby, Miniart, Rye Field, and Takom for future armor builds.
Thanks for looking.
    July 2004
Posted by stikpusher on Tuesday, July 25, 2023 8:44 PM
Very sharp looking build Hoss. Did those two crew figures come with the kit?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by keavdog on Tuesday, July 25, 2023 9:19 PM
Fantastic looking build.  I wonder if the beast survived Kursk.
Well done, great details and great finish.
Thanks,
John
Posted by Gamera on Wednesday, July 26, 2023 6:48 PM
Wow, she looks fantastic! I love the camo.
I've got the Tamiya Panther G in my stash, I hope I can get mine to look 10% as yours!
    July 2019
Posted by Hoss WA on Thursday, July 27, 2023 6:15 PM
stikpusher
Thanks stikpusher. Much appreciated. Yes, the two crew figures came with the kit. Interesting for Tamiya as I'm used to the commander figure standing straight and tall in the cupola for most of their armor kits. Thanks again.
    July 2019
Posted by Hoss WA on Thursday, July 27, 2023 6:16 PM
keavdog
Thanks keavdog. Glad you like it. I've wondered the same but haven't found any information.
    July 2019
Gamera
Thanks Gamera. Much appreciated. I'm sure yours will be awesome.
Posted by T26E4 on Friday, July 28, 2023 8:53 AM
Looks nice!  I like the look of those debut Panther Ds!
Roy Chow
Join AMPS!
http://www.amps-armor.org
    July 2015
Posted by MR TOM SCHRY on Friday, July 28, 2023 9:14 AM
Hoss WA, this looks fantastic!  It really comes across as a "war weary" veteran. The camouflage scheme is spot on and your figures look terrific.  I've noticed that Tamiya's figures have gotten a lot better over the last few years.  I've got this kit in my stash and now I really want to start it.  BTW your photography skills are also very good.
TJS
    July 2019
Posted by Hoss WA on Friday, July 28, 2023 12:55 PM
MR TOM SCHRY
Thanks Tom! Much appreciated.
    July 2019
Posted by Hoss WA on Friday, July 28, 2023 12:56 PM
T26E4
Thanks! Glad you like it.
    June 2004
Posted by TigerII on Friday, July 28, 2023 1:48 PM
This is an excellent Panther D, Hoss. Great work. She looks heavy and the figures are well done. Two thumbs up.
Achtung Panzer! Colonel General Heinz Guderian
    July 2019
Posted by Hoss WA on Sunday, July 30, 2023 8:08 AM
TigerII
Thanks TigerII!  Much appreciated.
    January 2021
Posted by JoeSMG on Sunday, August 13, 2023 3:31 PM
Beautifull build and terrific write up.
- Joe the SMG
    July 2012
Posted by Hasenpfeffer on Tuesday, October 3, 2023 10:05 AM
Awesome job, Hoss! There must have been something in the air, because I built an Ausf D from the 52 PzAbt at Kursk about the same time. (544)
I really like how you recreated the original photos. You were a folding chair, clevis and a few weeds away from fooling me on that last one. ;)
