Painting vinyl tank tracks
    September 2003
Posted by KevinCollins on Monday, April 26, 2004 8:54 PM
Hi All,
Just wondering about painting vinyl tank tracks that come with most kits…Last time I painted a set the paint all flaked off after a short time…btw I did was them with soap and water before painting…they were primed too…
Thanks….
Pray for Surf! Proud sailor (USNR) of IBU 21...NCW Group2
    July 2003
Posted by Foster7155 on Monday, April 26, 2004 9:10 PM
It sounds to me like you made the same mistake I did orignally and painted the tracks with enamel paint. If this is true, enamel paint will not adhere to vinyl tracks and will usually end up coming off at some point in time. If you paint with acrylics, this shouldn't be a problem.
I now primer coat my vinyl tracks with cheap black acrylic artist paint (.99 cents or less at most retailers). Once this is completely dry, you can paint, drybrush, and weather the tracks with enamels or oils without fear of the paint flaking off.
Hope this helps.
Foster
Robert Foster
Pensacola Modeleers
Posted by Anonymous on Monday, April 26, 2004 9:13 PM
Were you bending the treads a lot after you painted them? Paint isn't going to stick onto vynil as well as plastic, so a lot of bending might make the paint flake and whatnot.
    September 2003
Posted by KevinCollins on Monday, April 26, 2004 9:19 PM
Thanks guys....I did bend them a little afterwards....now I know better...I'll pick up some of that cheap artist acrylic paint and give that a go...Smile [:)]
Posted by Anonymous on Tuesday, April 27, 2004 2:36 AM
Yeah, enamel won't work on vinyl.
