Looks quite nice thijs. I really like the camo and the tools look excellent.
Are you planning on any weathering?
If I may suggest a couple little things:
1. Drybrush steel on the tracks, idler rims and drive sprocket teeth these areas would be shiny from wear.
2. It appears there is an ejector pin mark on the inside of the schurtzen (side armour) at the front, a little putty and sanding will cover those (or just sanding if they stick out from the panel.
Overall a real nice build, keep it up and
to FSM
