Tips please: How do you sratchbuilt a tyre and a wheel
Posted by Nuno Andresen on Saturday, May 1, 2004 8:46 AM
Take for example the Lav-25 tyres. How would you made them if you wanted to make tyres and the thread pattern without having the possibility to adapt a part from a kit donor. And how would you made a logo like "continental" or "good year" in that tyre.
Please tell me how do you do it. Smile [:)]
Posted by Anonymous on Saturday, May 1, 2004 9:05 AM
There are a couple of ways you could do it that I know of but I only have experience with one of them... The way I am going about it for my Hummer is I put two of the kits wheels together... One one I completely removed the tire protion of the paltic part and on the other I made sure that I only took out the rim (wheel)... I made molds with RTV rubber of both peices... The wheel part I am going to cast in resin... ANd when it gets here...Micro-Mark has some casting stuff that makes actual rubber tires... I am going to try that and see how it works out... If it looks half as good as I want it to the I am going to be a tire making foolBig Smile [:D]
Hope this helped a little..
Tom
Posted by Anonymous on Saturday, May 1, 2004 10:39 AM
Hi there nuno. Just like what Tom said, the only way you can do this is to mold it in resin or in Micro-Marks tire casting stuff. In making resin moldsyou should have a good pattern to make the mold out of, complete with the brand names & logo. And of course you'll need the resin & RTV mold stuff. With regards to LAV-25 tires & wheels, if you can't do the resin casting stuff, there are AM stuff out in the market. Check out mapleleafmodels.com.
Posted by Nuno Andresen on Monday, May 3, 2004 5:40 AM
Ex18B, alex amarra
: I thank you for this input but what I would like to know is really how to make a wheel from zero.
Imagine that it was for an OTO Melara or something that odd and nothing similar to use as donor was availliable
How is possible to sculpt a tyre pattern in a circular rim made from: let's say: stock plastic, aluminum, etc...
Posted by Anonymous on Monday, May 3, 2004 5:47 AM
Use a lathe and turn the shape of the wheel (Less the treads) Ahdd the treads using some styrene. It's time consuming But worth it
Posted by Anonymous on Monday, May 3, 2004 1:00 PM
You've got me there nunoConfused [%-)]Confused [%-)]Confused [%-)] I haven't ever tried making one from scratch... Sigh [sigh]Sigh [sigh]Sigh [sigh] Good luck I am sure that some one will have the answer to your question...
Tom
