Bad fit
Bad fit
Posted by Anonymous on Wednesday, May 19, 2004 7:34 PM
I am building Dragon Model's M1A1HA Abrams ' Iraqi Freedom 2003' . Dry fitting the turret halves, I noticed that the bottom half, around the main gun opening, dosen't even come close to fitting properly. After some sanding, it's a little better, but not much. I would like to cut out the areas that don't fit and redo it...but I just don't have that kind of skill...but I might do it anyway !!!! Got to learn sometime. Has anyone in the forum run into this problem? What thickness shhet plastic should I use to rebuild the bad fitting area? The main problem is the angled areas on the bottom half of the turret where it ' leads' to the main gun.
    July 2003
Posted by Dwight Ta-ala on Wednesday, May 19, 2004 7:48 PM
jpfracer,
I have built the said kit. And I know what you mean. What I did was glued and fixed the upper and bottom turret. When it is firmly fixed, I applied putty in the gaps and sanded them off. Application of the putty maybe done in thin layers for better development and drying of the putty. It mught be the easier way to go.
Good luck.
Posted by tigerman on Wednesday, May 19, 2004 8:36 PM
Same problem with my Tamiya M1A1. I'm puttying.
 Eric
Posted by Anonymous on Wednesday, May 19, 2004 8:47 PM
My friend built that exact same model. He told me that whatever I did, DO not buy that kit. Looks adicting and nice on the shelf but I remember seeing the bad fits everywhere and remembering his words.
    July 2003
Posted by Dwight Ta-ala on Wednesday, May 19, 2004 8:53 PM
But don't be discouraged. We can't have a perfect kit all the time. Besides, it does really feels good if we can come up with a good build inspite of the bad fits.
Posted by Anonymous on Wednesday, May 19, 2004 8:54 PM
Built the same one for the M1 GB and yup I know the feeling, basicly did the same as Dwight and it does turn out to be a graet looking kit when finished would show ya mine but Ron's site is down where the pics are at however if you klick on dwights name and then his home page you can view his which is a great looker or even look around in the M1 group build thread.....good luck and have fun with it.
Posted by Anonymous on Thursday, May 20, 2004 5:18 PM
Thanks for the advice. It will be a good skills building experiance. I did have to glue the gun end of the turret halve together and let it set real good...then I did the back end...it took some clamps to hold the back end tight. I do have both white and green squadron putty...what is the differance? Can it thinned so as to go on more creamy? The kit really is well detailed, more so that the Tamiya M1 I built last year.
Posted by kaleu on Thursday, May 20, 2004 5:59 PM
It's unfortunate that all of the M1 kits on the market need several things done to them to make them close to accurate. As much as I want to buy the Tamiya M1, I just can't justify the cost ($40-45, most expensive M1 in the stores) since it is missing the anti-skid texture, which is very obvious on the real thing. I have read that the best way of building an accurate M1 is to take the new Tamiya turret and use it with the Trumpeter hull. Follow this link for a comparison of the Abrams kits:
http://vodnik.net/index_m2a2.htm
Erik "Don't fruit the beer." Newest model buys: More than I care to think about. It's time for a support group.
    July 2003
Posted by Dwight Ta-ala on Thursday, May 20, 2004 6:16 PM
Sorry but I have not used squadron putty. I have only used Italeri and Tamiya. Between the 2 I prefer using Tamiya because of better consistency and fineness(correct word?)
Posted by Spamicus on Thursday, May 20, 2004 8:54 PM
Squadron green is what I normally use. I haven't used the white, but I read some place that it's got a finer grain than the green, so it should be smoother. I thinned the green once for a zim project, I used liquid model cement to thin it, but that cuts down your working time. Try a couple of test runs on a junk kit before you go after your project.
Steve
