wire mesh for panels and engine intake grills
Posted by renarts on Saturday, May 22, 2004 10:08 PM
While at the art supply store today, I found a product called Wire Form or Contour Mesh. It is a fine brass, copper, or aluminum mesh that is used for sculpting forms and craft projects. It comes in various densitys and is perfect for afv grills, mesh etc.
It is produced by 3 different companies.
Amaco
Activa Products
Paragona
Each one has a pattern or packaging peculiar to them but its pretty much the same.
It is square woven mesh or it has a diamond pattern and is inexpensive. A 16"x20" sheet runs about $8.00.
I saw that Michaels Crafts had some as well as Pearl Art Centers. I figure it will probobly show up in any "art supply" store or place that handles ceramics or modeling & sculpting clays.
Posted by Anonymous on Saturday, May 22, 2004 10:47 PM
Sounds like a great find, thanks for the heads up.
    June 2003
Posted by M1abramsRules on Saturday, May 22, 2004 11:00 PM
I found another idea as well
working the last couple weeks at a farm implements dealership (largest of its kind in North America Thumbs Up [tup]) I found that the sprayer nozzles have little strainers in them with very fine mesh. you can get several different sizes of mes, too!!! you'd probably get about 18 square inches of it from a strainer for about $1.60 or so. (canadian funds too)
Posted by JCon on Sunday, May 23, 2004 12:05 AM
Great ideas guys, keep sharing those tips!
Happy Modeling, Joe Favorite Quote: It's what you learn after you know it all that counts!
    July 2003
Posted by lizardqing on Sunday, May 23, 2004 1:49 AM
Great finds, definatly cheaper and more readily available than PE.
    January 2004
Posted by gdarwin on Sunday, May 23, 2004 2:21 AM
Big Smile [:D] i found something preety close to the same thing at hobby shop,it is brass and in a dimond pattern not sure about the price ,but it would look good as a grillBig Smile [:D]
gdarwin.[roy]
airborne death from above http://photobucket.com/albums/a350/roygd/
    September 2003
Posted by maffen on Sunday, May 23, 2004 11:11 AM
i've got the other day some (5) round disks with handle that they use for splatterpainting with a toothbrush (i think) they were only 1€ a piece Tongue [:P] think they are in aluminium. well i used a technique on them that i always use for blackening copper chains : bleaching agent +hydrochloric acid+kalium polysulfide (don't use make it inside because it's smells like a stinkbomb Laugh [(-D] put the mesh in the mix and went to take a look afther about 5 hours and it was totaly gone Banged Head [banghead] never going to do that again Big Smile [:D]
Posted by renarts on Sunday, May 23, 2004 11:21 AM
This has been a sort of background project for me. I've been looking for cheap, readily available substitutes for PE that will work for things like grills, fencing, etc. I know there are some filter screens (like m1 posted) and some other materials that will work fine and once painted will be acceptable for a multitude of applications. Its just finding the stuff as its used in other applications.
Tulle
wire form
aerator or debris screens from faucets
paint filters from paint stores
intake filter screens
dryer lint filter screening
All have produced some very interesting results
    January 2003
Posted by Keyworth on Sunday, May 23, 2004 8:20 PM
Gang, even replacement screen door screening can be used. It' s usually made of plastic these days, and can be easily cut to fit most anything. The pore size is a bit large, so it's use is somewhat limited, but I've used it a time or two with good results.
"There's no problem that can't be solved with a suitable application of high explosives"
    May 2003
Posted by Build22 on Monday, May 24, 2004 6:24 AM
There's alot of stuff there that works for different things
I grab the goggle eyes and use them ( less the little pupil of course) for light lens
Alot of great paint accessories too
Thanks for the tip
Jim [IMG]
