Beginner kit Ideas
Beginner kit Ideas
Posted by Anonymous on Monday, May 24, 2004 11:34 AM
My birthday's coming up and along with an airbrush (anyone have any suggestions on the make I should get?) I wan't to have another kit to do over the summer. I'm not a beginner as in I don't know what I'm doing, but I'm not that skilled yet Blush [:I] does anyone have any good suggestions for kits?
    January 2003
Posted by wipw on Monday, May 24, 2004 11:54 AM
This is kind of an open couple of questions.
First, how much are you wanting to spend on an airbrush?? If you want a good, general purpose brush that doesn't cost an arm and a leg, consider a Badger 200. If you want a nice, high quality brush, consider a Badger Anthem, Crescendio, or one of the Iwata's. You'd probably be best to consider getting it from an online company like BearAir.com. Although, if there's a Michael's near you, watch the Sunday paper for their 40% off coupons. They carry the Badger brushes. Also, you need to decide if you want a single or double action airbrush.
Some people like, and swear by, the Aztec brushes. I have one and have had pretty good luck with it. It's easier to clean than most of the others. But I still like my Badger 200 better for most work. In my area, it's also becoming harder and harder to find parts/accessories for my Aztec.
As far as kits go, give us an idea as to what your interests are. Present day, WW II, or WW I? German, Japanese, or Allied? What scale do you want to do? 1/72, 1/35, or larger?
We'd be glad to give you some ideas, if you let us know a little more.
Bill ========================================================== DML M4A2 Red Army ========================================================== ========================================================== -- There is a fine line between "hobby" and "mental illness". (Author unknown)
Posted by tigerman on Monday, May 24, 2004 12:08 PM
Like Bill I have a Badger 200. Best brush I ever owned. I don't think I need a fancier brush than that myself, but it might depend on what you build. I am into armor period. It seems to make fine line camo if need be. You can probably pick one up for under $40 at Michaels. The thing you'll want to consider after that is a decent compressor. I bought mine at target for about $70. It's the only way to go, because those cans are expensive, and there is no regulator or water trap on them. Good luck.
 Eric
Posted by Anonymous on Monday, May 24, 2004 12:34 PM
[Quote=wipw]As far as kits go, give us an idea as to what your interests are. Present day, WW II, or WW I? German, Japanese, or Allied? What scale do you want to do? 1/72, 1/35, or larger?
Whoops, I just realized that now. I prefer WWII armor, the country doesn't matter, though I want to try some German armour, the scale 1/35.
BTW what are the advantages and disadvantages of double and single action airbrushes? The guy at my LHS said something about in a double you can control the air or something like that but I can't remember comepletely.
Posted by tigerman on Monday, May 24, 2004 12:40 PM
Double action airbrushes control the air and the amount of paint released. The Badger 200 is a hybrid in that it basically is a single action brush, but has a knob on the end that controls the amount of paint released.
I would go with most any Tamiya kit. The early Sherman was a very easy kit to assemble and only one color. The German Panther kits are very nice also. the only drawbacks to the Tamiya kits are the price. Go online and save some money. Also the venerable Panzer II and T-34 kits which are older and not as accurate as today's newer kits, but they are affordable and build up easily enough. You can always get aftermarket parts to enhance them.
 Eric
Posted by Anonymous on Monday, May 24, 2004 12:57 PM
I was thinking about a sherman as well, what do you mean by early, M4, M4A1?
    January 2003
Posted by shermanfreak on Monday, May 24, 2004 1:15 PM
Tamiya's M4 Sherman #35190 is a great kit to start with. Tamiya's engineering is top notch.
Other kits to consider would be Tamiya's Panther G's and T-34's.
Probably best to avoid anything from Dragon for the first while, individual track links will drive you crazy if you're not too experienced.
    January 2003
Posted by wipw on Monday, May 24, 2004 1:52 PM
Airbrush:
Single action. The button on top controls the amount of air. The amount of paint is controlled in some other method, if at all. The Badger 200 has a "nut" on the back of the handle you can turn out (counter clockwise) to increase or in to decrease the amount of paint and therefore how wide the spray pattern is. They are easier to use, but very dificult to adjust the pattern when using.
Double action: The button controls both the amount of air, by how far down the button is pressed, and the amount of paint, but how far back the button is pulled. It is easy to change the spray pattern, but learning to do it properly and therefore being able to get the results you want is more difficult.
The double action Aztec brushes can be adjusted to act like a single action brush, if desired. One advantage of this is you can set it up as a single action and, after getting used to it, change it to work as a double action.
Kits:
Tamiya's Tiger I kits are all supurb. I'd stay away from any of the open topped (i.e. the Marder III and Marder IIIM) kits to start. For your first kit or two, avoid the impulse to get after market (AM) detail kits for it. (Exception to this might be a metal barrel) Get a kit that looks interesting to you and just have fun building it up. It's hard to go wrong with the newer Tamiya kits, although, as mentioned, they are expensive. Once you get a kit, jump on here and ask specific questions and the members will help with tips and techniques.
The main thing is to have fun!
    May 2003
Posted by Panther 44 on Monday, May 24, 2004 2:28 PM
ManiK_Impressive,
If you are thinking of a Sherman, may I suggest the Tamiya M4A3 kit #35122. It's an older kit but I think makes a nice kit and you can still find them rather cheaply (they are out of production).
Regards,
Joe
Just remember, ignorance is no excuse for the law. - Moe
