Olive Drab color for the Sherman
Posted by ipms40049 on Saturday, June 5, 2004 8:00 AM
Ok, out of the Model Master colors, which OD is best for the Sherman?
even if I have to mix something up. I have two days to finish this kit and cant order any tamiya OD, i only have access now to my local Hobbytown USA which only carries the Model Master line, and some Floquil.
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
Posted by Anonymous on Saturday, June 5, 2004 10:55 AM
The MM OD should be just fine.
Do they make more than one OD?
    July 2003
Posted by Foster7155 on Saturday, June 5, 2004 11:10 AM
I normally use the the MM OD as the base color and MM Faded OD for drybrushing and highlights.
Robert
Robert Foster
Pensacola Modeleers
Posted by Anonymous on Saturday, June 5, 2004 12:18 PM
Sign - Ditto [#ditto] You can even paint it in the faded OD for something different.
Posted by Anonymous on Saturday, June 5, 2004 12:45 PM
I always just use the MM OD, works great for me
    May 2003
Posted by Panther 44 on Saturday, June 5, 2004 1:01 PM
Hi marder 40049,
If you are looking for matches for the MM OD Green (FS # 34087) in a book by MM called Modelers Technical Guide it gives the following references:
1. Floquil Classic Enamels #303108 (fairly close match)
2. Floquil Poly Scale Acrylics #505370
3. Floquil Poly S Acrylics #500052
Hope this helps.
Regards,
Joe
Just remember, ignorance is no excuse for the law. - Moe
Posted by Spamicus on Saturday, June 5, 2004 8:31 PM
I use MM enamel OD #34087 for most of my Shermans. I used MM Acryl OD #4728 on one, it's quite a bit lighter in color, but still very satisfactory.
Steve
