Brush strokes? How do I get rid of them?
Posted by Anonymous on Sunday, June 6, 2004 8:04 PM
I just laid down the main coat of paint on my p-51. It is the aluminum color from testord. There arent a lot, but there are a few brush strokes here and there. How should I go about getting them out? I have about 6 sheets of testors sand papers ranging in grit, is this a possibility?
thanks in advance for the help!
    October 2003
Posted by rebelreenactor on Sunday, June 6, 2004 8:26 PM
I'm not sure if its possible to sand them down. Have you tried using spray cans? Or an Airbrush? These 2 things should give you a smooth coat.
Try posting this quetion in the paintin or techinques forum. youwill get better answers.
John
    July 2003
Posted by Foster7155 on Sunday, June 6, 2004 8:42 PM
You can probably sand them out, but you will definitely have to put additional paint on afterwards. Before you even consider sanding, ensure that the paint is 100% cured. I would wait at least 3 - 4 days (from the day you painted the model) before attempting to sand.
If possible, use wet/dry paper and sand wet starting with the finest grit you have (just the opposite of sanding down imperfections). If this gets the marks out to your satisfaction, then you're good to go. If not, move up in grits as needed until the brush marks are almost completely removed. Then come back down in grits to the finest you have. This will help remove any scratches from the heavier grit papers while finishing removing the brush marks. A major concern is that you will also remove any raised detail.
Good luck.
Robert Foster
Pensacola Modeleers
