color recommendations for m60a1 with rise/passive armor
Posted by Anonymous on Monday, June 7, 2004 4:00 AM
can anyone please give me ideal colors for the m60a1? i'm used to building modern aircraft and it's my first try on armour. i only have access to tin can acrylic sprays from Tamiya. i also need to know what color you use for your tracks. my kit is a 1:35 from academy. color schemes prior to desert storm are preferd. thanks!
Posted by Rob Gronovius on Monday, June 7, 2004 6:08 AM
I don't know about Tamiya spray cans but they make an excellent NATO green, brown and black that is very good for the colors you will need. Those tracks are mainly metal with a rubber pad and interior surface. Paint them some sort of earth tone (look at construction equipment nearby your home). Use a darker gray to pick out the rubber color and then dry brush the tracks tan or sand color.
Posted by Anonymous on Monday, June 7, 2004 10:57 PM
thanks. i'll try that one.
    April 2004
Posted by crockett on Tuesday, June 8, 2004 6:36 AM
In Germany, we spray painted our 60's with green, brown and black. 3/33 armor / 3rd AD. There were variations of this unit to unit (pattern wise). Stateside, there were sections of light gray in the camo scheme, ( Ft. Carson, 4th ID I believe). Our Rise Passive were delivered with a different type of track than the older tanks. This "new" type had individual replaceable pads that required an extra bolt to secure the pad to the track block. This was intended to ease the maintenance chore of breaking the track and replacing a whole track block when the rubber chunked off. Color wise, no difference. The end connectors, sprocket and center guides should show bare metal wear, unless your tank has been sitting in the motor pool for a while. Rear Grille door fins should be a smoky rich flat black, (diesel exhaust).
Can't wait to see your finished product, good luck,
Steve
