tiger I early paint schemes
Posted by Anonymous on Monday, June 14, 2004 9:17 AM
hey all,
just got my tiger I early in the mail. the directions call for either a field green (tunisia) or flat tan (scicily) color, both by model masters. i dont have an airbrush yet so i use spray cans to base coat my models. which tamiya spray colors would be similar to these? also, which camo schemes would be appropriate for the early tigers? just looking for some feedbak on a good paint scheme for this model. thanks for any help.
Posted by Anonymous on Monday, June 14, 2004 9:37 AM
You may want to try some of these links to other's posts for Ideas....
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=21696
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=19691
Here are pics of thundergod's EXCELLENT paint scheme:
(thundergod, if you wish, I can remove those.....)
Other links to valuble posts:
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=6369
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=20780
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=17894
I hope that some of these links can be of some help to you.
regards,
MARCSmile [:)]
Posted by Anonymous on Monday, June 14, 2004 9:58 AM
Hi trailer36
Great reply by wwIIsoldier aka Mark so I can only add that I have recently made a Tiger II which has the same basic colour scheme as the Tiger I, obviously depending on year and theatre of war. All tanks came from the factory sprayed in a base yellow colour and the the units added camoflage upon delivery. Most in Europe used a three colour (yellow, brown,green) system making sure to mask corners, jagged edges etc. Tamiya make a yellow spray can but be sure to atomise it before spraying (stand in hot, not boiling water for 5-10 mins) or it can be a bit 'rough'. For the brown and green you will need to get hold of a small spray gun as hand painted you will be dissapointed and it looks bad if I'm honest. Numbers are:-
Tamiya TS-03 Dark Yellow
Tamiya XF-61 Dark Green
Tamiya XF-10 Flat Brown (looks very much better than Red Brown)
I started with the spray cans but found I needed loads so changed to a spray gun (1/16 scale).
Hope this helps, Good luck, let us know how you get on
Dave
Posted by Anonymous on Monday, June 14, 2004 9:59 AM
Yes, Thundergod have a very beautyful model, but it is a late Tiger I, and the early Tiger didn't have that camo scheme.
The early Tigers were painted grey in the begining, later they did get some camo.
Bovington tank museum have just finished restoring their early Tiger I from Tunisia.
Maybe it can inspire you, here are a couple of pics. Some of the pics may be Captain Caveman's, I hope its allright I put them here Captain Caveman.
Posted by Anonymous on Monday, June 14, 2004 10:10 AM
Sorry for that, I didnt realise it was late. My mistake. That is an awesome tiger monrad posted, as you can see, camo isnt necessarily all that they used on the tiger. A much simpler paint scheme can get you just as nice of results.
Posted by Anonymous on Monday, June 14, 2004 10:21 AM
nice, thanks guys. i think i will try either the field green or the panzer grey colors as a change of pace for me. i did a panzer IV in panzer grey that turned out really good so we'll see.
Posted by Anonymous on Monday, June 14, 2004 10:28 AM
Wow !!!! thanks Mark .(my head is getting bigger .....hehehe just kiddin)
Its ok that is what they are there for. I actualy di not like this particular paint job but I have got nothing but good remarks from it. Must be that one hit wonder thing. hehehe.And as Monrad said it is indeed a Late Tiger I. You can prettymuch look at the two and see the differances. And by the way I beleive that is the only fully running Tiger in existance.
    January 2003
Posted by wipw on Monday, June 14, 2004 10:47 AM
The only Tiger I. I think there is a Tiger II somewhere, also.
trailer; I don't think the German's ever painted a Tiger in a solid green color. Towards the end of the war, it's possible the used green as a primer as they were using about anything they could get their hands on. But an early should be either solid fieldgrau (field grey) or dunkelgelb (dark yellow). The units in the filed in Africa added some brown or green camo, I believe.
Good luck. We'll enjoy hearing of your progress. Make sure you post some pics when you can.
Bill ========================================================== DML M4A2 Red Army ========================================================== ========================================================== -- There is a fine line between "hobby" and "mental illness". (Author unknown)
Posted by Anonymous on Monday, June 14, 2004 11:43 AM
yeh guys, i have a couple pics to post also of my other two models. thanks for the help.
Posted by tigerman on Monday, June 14, 2004 5:05 PM
Tiger I Early I would go with Schwartzgrau and for later versions, the tri-color. I concur with Bill, I don't think they would have a green base either. They stopped producing the Tiger in August of 1944. This was primarily due to the emergence of the Kingtiger. Peak production reached a paltry 105 in April of 1944 compared to 2000 T-34"s!
 Eric
