Hi!
While waiting for my new AB to arrive I continue (the never ending) build of my Jagdtiger porsche.
Indy links ofcourse of the
porsche type....
I would like to put it in an abnormale (or is it normale..) surface, ie a dio where the Jagd is on a rough terrain. this way I could extand the potential of the indy links. the problem is the nomber per side.
Yes I understand it would vary between very tense and very loose tracks, so I'm looking for the MID nomber. the reason I need to do so, is because I'll need to fit the running gear to the ground, and I forsee the problem with making the sag at the upper side of the track.
nomber and thoughts will be welcome, thanks!
