Adding cast hull texture
Posted by Anonymous on Friday, June 18, 2004 6:12 PM
Is there an alternative to Gunze Mr. Surfacer for giving my Italeri M4A1 a proper cast hull texture? Apparently this stuff is hard to get. Nobody carries it locally, and I'd hate to pay $5 shipping for a $5 spraycan...
M.
Posted by renarts on Friday, June 18, 2004 6:24 PM
There is a product called Cast-a-Coat that will work for the non-slip surface.
I suppose anything you could add to a paint to make a texture would work.
http://www.ww2modelmaker.com/castacoat.htm
    December 2003
Posted by hunterw450 on Friday, June 18, 2004 8:00 PM
you could coat it with liquid plastic cement (i use testors) then texture it with an old paintbrush with the bristles cut down ( or some other stiff brush). or i have also made texture with a dremel tool and a grinding bit. you just kinda "bounce" it around on the surface then smooth it out with steel wool. hope this helps!
wes
    December 2003
Posted by spector822002 on Friday, June 18, 2004 9:11 PM
cast a coat is the way to go, I have seen it on a few models and it does look good .
Posted by HeavyArty on Friday, June 18, 2004 11:07 PM
I prefer the liquid glue method. I simply apply it to a small area(about two square inches), let set for a couple of seconds to soften the plastic, then use my finger as a blotting tool. Once the area is completed, I put another layer of the liquid glue over it to smooth it out slightly and tone down the finger prints. Next move on to another small section. I think it comes out looking great.
Posted by Spamicus on Friday, June 18, 2004 11:21 PM
I use the liquid glue and brush method. I use Testor's glue and a flux brush I got from the welding department at the hardware store. Work a small area at a time, lay the glue on pretty heavy and let it sit a minute or so then stipple the area with the brush. Looks good without being over done.
Steve
