Photoetch is hardly for everyone , the end result is pretty kool for sure , but some of the tiny details can be a good reason to check yourself into the local mental ward at the hospital, as said above don'y be afraid to use just a few parts from the kit . If you are going to enter the kit in competition , it just gives much more room for mistakes , stock is probably the better way to go there ! I like PE kits a lot they are really challenging , but man are they frustrating ! I do suggest you skip the detail on that wooden box if you have an ABER set , the hinges on that are going to drive you up the wall to the point of tossing the whole kit out the window ! Take your time , and do a little bit at a time , then put it away and do a fun stock kit , just so you may feel you are making progress! I have been working on a marder 3 kit for around 4 months now off and on , if I feel I am getting frustrated I just put it away , at this rate she may be ready for paint by this fall !
Oh and hint for cementing those really small parts together put a drop on waste paper and use a dull needle or toothpick to apply the cement to it , if it builds up on the needle tip ( and it will ) just burn it off with a lighter . Hackle pliers (from flyfishing supply) are great for holding fender type parts together while the glue dries or the solder cools ( solder will not stick to them ) Good luck ! And stay sane !
