I'm Better Now: The Gopher is Fixed! ! WARNING! Long Long Post, Loads of Pics!
    June 2003
Posted by Duke Maddog on Tuesday, June 29, 2004 10:17 PM
It's amazing what I can do when I recover enough to build decently again!
I had hit on this idea for how to repair my 1/72 scale ACE Sa13 Gopher while painting some accessories from another kit. I noticed some prominent number tabs that looked like they'd be good hinge pieces. They were round on the one end, and the other end would be cut flat. The arrows below point out examples of the number tabs I thought would work:
So, I cut four of them off, and then cemented them together back to back. Once they were dry, I shaved off the numbers on the outside. Then I drilled holes in them near the rounded end like so:
Then I took my X-acto and cut one side of the arch near the middle of the tab. After that, using the pointed tweezers in the pic below, I carefully opened the rounded part of the arch to make an opening large enough to fit around the brass rod that was still CA'd to the Turret launcher arms. Here you see the openings indicated by the arrows:
Then, I placed the hinge pieces on the brass rod and tried to carefully re-close the arches in the tabs. One hinge piece closed up just fine, the other hinge piece broke off and was rendered useless. Once I got the remaining one closed, I poured a little ZAP-a-Gap CA glue on a piece of plastic and used my No.11 X-acto to sparingly apply some CA to hold the cut ends together. As the first layer dried and held the piece secure, I carefully added subsequent layers of CA, checking each time to be sure that I didn't glue the hinge piece to the brass rod or to either of the launcher arms. The unit has to be free to move so that the launcher assembly can be posed in any position. Here is what the one surviving hinge piece looked like once it was secure on the launcher arm:
In the picture above you are looking up from the bottom of the turret, just so you have an idea of the perspective.
Now that one hinge piece was completed, I started work on the next one to replace the piece that broke apart. I cut it a little longer, figuring that I could trim it to size once it was mounted on the brass rod. Here it is with the hole drilled and ready to be cut:
(I apologize for the quality of this pic. The light I was using is on an arm that slowly drifted down too close to the subject, over-lighting it. It happened while the timer was going on my camera. I caught it after the picture was taken.)
I cut and opened the new hinge piece like the first one, and got it on the brass rod where it fit on well and closed easily. Using the same system as before, I carefully applied the CA glue (shown in this pic) to the opening, and sealed it up well. I used multiple layers of glue to insure security on this hinge as well. I checked to see that both hinge pieces moved and they move well. Here they are both on the brass rod of the turret:
After the glue had dried for about twenty minutes, I even sanded both hinges carefully and lightly to remove some of the uneveness from the glue.
Now it was time to add the launcher assembly. I trimmed the long hinge piece to the same size as the first one and checked to see that the launcher assembly would sit straight (!) before moving on. Then I made a small plate from another number tab and glued that over the stubs of the original hinge pieces. Once that was secured, I glued the launcher assembly to the hinge pieces, adjusted then to the ideal location, and then propped the whole thing up to dry:
While that was drying, I looked at the instruction sheet for the Gopher and saw that the radar dish was drawn on the instruction sheet with four rods (?) that came from the side of the dish and met in front of the middle of the dish. Naturally the dish wasn't molded with these on it as they are quite delicate at this scale. I also noticed that there was no assembly step showing how ACE expected it to be done! Question [?]Black Eye [B)] So, I improvised! Approve [^]
I took two lengths of stretched sprue, trimmed them down and; using my pointed tweezers once again, I folded them down the middle. Then I glued the folds together, making a very small open pyramid. After checking the fit on the dish, I trimmed the ends so that the 'pyramid' would fit on the dish. Once I was satisfied in the size and position, I glued the 'pyramid' in place on the dish face. Here is how it looked when I got done. The No.11 X-acto blade is for size reference:
Now, the launcher assembly and turret were dry enough, so I checked the movement to be sure nothing glued together that wasn't supposed to. Then I cemented the finished Radar dish to the front of the launcher assembly as per the instructions and placed the whole restored turret onto the main hull:
SUCCESS!!!
Finally! I am pleased that I will be able to finish this kit!
Maybe I'll send a link of this post to Alexei, the owner of ACE who posts regularly on another forum! Wink [;)]Big Smile [:D]
Of course, there were times when I had to wait till things dried while repairing that turret, and I wasn't idle during those times. I was able to finally finish all eight wheels on my Revell/Germany 1/72 scale Spahpanzer Luchs:
Man, I'm glad those linkages are done! The rest of this kit is going to be a BREEZE to assemble now that THAT is done! Wink [;)]Big Smile [:D]
I also thought that with all this stretched sprue lying around, I'd mount an antenna on my Monty's Scout Car, as well as replace the lost antennas on my Revell/Germany 1/72 scale Leopard 2A5.
Here is my Scout Car with it's new antenna, all shiny and waiting for decals that still need to be found:
And I can finally declare this German Leopard 2A5 to be finished:
WHEW! Dead [xx(]
I know this was long, and I deeply apologize to those with slow connections. I didn't really see how to break up the post without affecting the 'storyline'. I figured that some people would like to see how I was able to figure out the way I was going to repair this. Frankly, it helped to take pics every so often; it allowed me a chance to think things through and be more thorough as I went along, as well as check my work before I moved on.
Anyway, my apologies again, I hope this doesn't get me tossed for being so long and tedious! Black Eye [B)] Comments, constructive criticisms (besides: 'make shorter posts!' Big Smile [:D]) and suggestions are welcome!
Posted by Anonymous on Tuesday, June 29, 2004 10:26 PM
Well glad I am on cable. That is good stuff and good thinking. See ya take a breath focus on something else and you have a "wait a second!!" moment.
    October 2003
Posted by rebelreenactor on Wednesday, June 30, 2004 12:03 AM
I think i would go blind after tryinging that. or i would get frustrated because the peices would keep "tweaser Snapping".
Great job. Glad your feeling better.
John
    April 2004
Posted by yw18mc on Wednesday, June 30, 2004 12:11 AM
Mark, nice repair on your m1 tank. I just don't know how you guys do it with the micro min models. of course if my eyes were a little younger I'd probably give it a try myself. thanks for sharing. semper fi, mike
mike
    December 2009
Posted by wildwilliam on Wednesday, June 30, 2004 6:23 AM
Duke,
great save!
and a great post.
yes, it's long, but most of the time i find myself wishing for more info
when i see peoples builds and fixes.
thanks for taking the time to walk us thru it.
    June 2003
Posted by Duke Maddog on Wednesday, June 30, 2004 10:22 AM
QUOTE: Originally posted by wildwilliam
Duke,
great save!
and a great post.
Thanks Wildwilliam! I was so worried that people would be upset that I made such a long post about how I fixed this. It still might explain the few responses I got though; it looks like many stopped waiting for it to download! Dead [xx(]
I'm cool with that though, since I kind of expected it when I was making this post. I do feel bad for those on slow connections.
I'm glad I was able to satisfy your wishes for more information. I found it to be quite fun taking the picrues, and thinking about how I was going to post this while I was repairing it.
Thanks Rebel! I was quite surprised that things didn't 'tweezerpult' off into Oblivion, although I did have to chase a few parts on the Spahpanzer Luchs.
Thanks Mike! I do have to say it was a Russian Sa 13 Gopher SAM system I was fixing though, not an M1! Blush [:I]Wink [;)] I do very much appreciate that you took the time to look at my long, tedious post! Approve [^]
Finally, Thanks woodbeck you are right. I don't have many of thise "wait-minute!" moments, but I love when they happen. Wise words indeed!
    September 2011
Posted by fightnjoe on Wednesday, June 30, 2004 2:40 PM
well done duke. worth the wait.
joe
Veterans,
Thank You For Your Sacrifices,
Never To Be Forgotten
Where you can find me:
Workbench on FaceBook  Google Plus  YouTube
    January 2003
Posted by wipw on Wednesday, June 30, 2004 3:22 PM
Way to go, Duke. Nice job. Your ability to think things through and come up with a workable fix are amazing. And I didn't find your post tedious to read. It was very interesting. I love the job you did on the glass(?) panel below the launcher. Very realistic looking.
Thanks
Bill ========================================================== DML M4A2 Red Army ========================================================== ========================================================== -- There is a fine line between "hobby" and "mental illness". (Author unknown)
Posted by Anonymous on Wednesday, June 30, 2004 4:22 PM
Top Notch Save!!! Don't it feel great to know the kit didn't beat you!!!
    July 2003
Posted by Dwight Ta-ala on Wednesday, June 30, 2004 10:52 PM
Another great one. Duke. Wheww. Those things are tiny.
    June 2003
Posted by Duke Maddog on Thursday, July 1, 2004 12:17 PM
Thanks
Thanks Will! Thye 'glass' pamelk is actually a piece of clear plastic cut from a blister pac. For those from other countries, a blister pac is one of thise clear, semi-hard plastic casings that holds merchandise to the cardboard backing of the package. They are typically used to hang merchandise in the stores. I found one with a flat section and cut a piece out, sized it, then glued it into place with Testors window cement.
Kenneth, Yes It Does feel good that the kit didn't win! It is an ACE kit, so it had a fighting chance to win, but I came through instead!
Thanks to everyone else who enjoyed this article. If I ever have any more fixes to do, I'll show them this way again. Smile [:)]
Posted by Anonymous on Thursday, July 1, 2004 12:38 PM
Duke:
looking good, Comrade !
it is nice 2 read a 'play-by-play' of a good fix,
both inspirational & informative...
this is exactly the kind of stuff that makes this site so great,
sharing techniques 4 making better models, so
no apologies necessary from where i sit ! Big Smile [:D]
glad 2 hear ur feeling better &
thanx 4 sharing ur work & the process of building it w/ us !
frostySmile [:)]
Posted by philp on Saturday, July 3, 2004 12:38 AM
Duke,
What decals are you looking for on that scout car?
Bison makes a decent set for Recce and Scout cars that might have what you need.
http://www.angelfire.com/pro/bison/72007.html
Phil Peterson IPMS #8739 Join the Map http://www.frappr.com/finescalemodeler
Posted by Buddho on Saturday, July 3, 2004 1:27 AM
Great job on the fix and on the models, Duke!
I look forward to your posts...I know it'll be filled with more than one model and have alot of info on your work.
Regards, Dan
    June 2003
Posted by Duke Maddog on Saturday, July 3, 2004 12:35 PM
QUOTE: Originally posted by philp
Duke,
Thanks for that info Phil, but I'm simply looking for the decal sheet that came with the kit! Blush [:I] I lost it somewhere, and I still need to find it. I also need to decal my Monty's Caravan truck as well, but I'm trying to find materials to build the interior furniture.
I am keeping that link though, I surely need alot of the decals they are offering! Thanks for sending it! Wink [;)]Cool [8D]
Thanks Dan! I appreciate that someone looks forward to my posts. I have a few more projects to start soon, but I need to finish a couple of the ships and aircraft I've got on the bench before I can start another few kits.
Thanks again for the kind words. That's what keeps me motivated to build on!
