Thinning Acrylic Paint?
Posted by Anonymous on Thursday, July 8, 2004 3:23 PM
Hello all, I am new to this forum and also new to Armor. I have not built a model in a very long time and am starting all over again, and the Armor models look really cool to build. I would like to know what is best to mix with Acrylic Paint to be used in a airbrush. I know they have the little bottle of thinner but they want way to much money for that little bottle I figured I could go to a hardware store and buy a big bottle of somthing alot cheaper. Also what is the best mixture to use? 2 parts pant to 1 part whatever you guys tell me to use? Or would a differnt mixture be better. Thanks for all you help in advance. A friend showed me this board and there is alot to learn from all of you. Take care.
Scott
Posted by Anonymous on Thursday, July 8, 2004 3:57 PM
You could use rubbing alcohol. Try to find the 90% stuff. Tamiya thinner is also available in big containers, but it's still expensive. Still, IMO there's no beating it for thinning Tamiya acyrlics. Other companies make stuff called "acrylic airbrush medium," but try it first on the particular paints to see if it works.
Do not and I repeat do not use wiper fliud. I foolishly did that once and flirted with liver damage.
Posted by Anonymous on Thursday, July 8, 2004 5:09 PM
Welcome to the forum Scott
Personally, I use the Tamiya Thinners, although it is a little expensive. I have found that it is the best to ensure the pigment is properly broken down.
After all, you spend AUD$50+ on a Tamiya or DML kit, maybe a small fortune on PE and replacement tracks if you are that way inclined, another AUD $4 for each jar of Tamiya Acrylic paint, why then skimp on the AUD $1-$2 worth of thinner that you will use?
Thinning ratio depends on your airbrush and the colour you use. I find that darker colours can be thinned better than the lighter ones. I use an Aztek, and although a few people bag this brush, I have found it far superior to the Badger I have and the Paasche my friend has and I have used. Testors (Aztek) recommend the consistancy of milk (they don't say full cream or skim!). I judge it by eye, but test on scrap before touching the kit.
Posted by Anonymous on Thursday, July 8, 2004 5:30 PM
HI Scott,
I'm going to have to go with the Tamiya Thinner as well if you are using Tamiya Acrylics. It is more expensive, but you will be suprised how long a bottle will last you. It's not worth trying to get something cheap to save a few bucks as it can really affect the quality of coats of paint when you lay them down.
As for ratios, it does depend on the airbrush and the colour, but a starting point of 1:1 or even 1:2 paint to thinner is good and start from there. After a few goes you will get the feel for it and know by looking at it when it is right. I know that sounds like a cop out when your just starting out agoing when everyone says it will come with practise, but trust, after few months it dows become second nature.
Adam.
    January 2003
Posted by wipw on Thursday, July 8, 2004 5:48 PM
Welcome, Scott. I've got to go with the above. I usually try and use the matching brand for thining my paints. However, that doesn't mean I use it to clean my airbrush. (I use a Badger for enamels and an Aztec for acrylics). To clean my brushes (whether they be regular brushes or airbrushes) I use generic alcohol for acrylics and paint thinner (mineral spriits) for enamels.
Good luck and, again, welcome to the forum.
Bill ========================================================== DML M4A2 Red Army ========================================================== ========================================================== -- There is a fine line between "hobby" and "mental illness". (Author unknown)
    July 2003
Posted by lizardqing on Thursday, July 8, 2004 6:33 PM
Welcome to the forum!
I use denatured alcohol for my acrylics with pretty good results since I have no real availability of the proper thinners. As afr ratio, I do like others and go with what works.
Posted by Anonymous on Thursday, July 8, 2004 11:40 PM
Hey all thanks for the reply's. Once again like I said you guys have a wealth of knowlege and there is alot to learn from you guys! I will go with the Tamiya Thinner, like you guys are saying why skimp when working on a nice model. Thanks again for all the help!! I'm sure you guys will be hearing from me again. Take care!
Scott
