Weird wheels on that T-34 in the picture! (Look at the pic!)
Posted by Anonymous on Monday, July 19, 2004 8:19 PM
This is just weird, I've noticed that on the first two tanks in the picture one of the wheels is different. can you tell me why and was that often. Smile [:)]Big Smile [:D]
http://homepage1.nifty.com/gizmo-cafe/tank-photo/t34photo/t34photo_2.jpg
Posted by tigerman on Monday, July 19, 2004 8:22 PM
I've seen mix and matched wheels. I don't really have an answer, other than they may have been desperate to get them built that they used older wheels along with newer. Certain factories may have had a limited stock of one or another.
 Eric
Posted by Anonymous on Monday, July 19, 2004 8:24 PM
I guess, but did you notice that the size is too big, that even the tracks are a bit higher on that wheel in that place!
Posted by Anonymous on Monday, July 19, 2004 8:25 PM
Or is there something wrong with my eyes!Smile [:)]
Posted by Anonymous on Monday, July 19, 2004 8:37 PM
is it possible that there this just so much mud and grass clogged into the roadwheel that they look awkward, my eyes might apparently be bad but thats what it looks like to me.
    July 2003
Posted by Dwight Ta-ala on Monday, July 19, 2004 8:37 PM
I think the big one is steel rimmed while the smaller ones are rubber rimmed.
Posted by Anonymous on Monday, July 19, 2004 8:39 PM
wait my mistake i was looking at T-34s picture underneath his posting that i didnt see the link, lol...wow i feel like an idiot.
Posted by Anthony on Monday, July 19, 2004 9:36 PM
I am not sure I am 100% right. But I've been told that there is a period of time that at around late 1942 to 1943, some Russian T-34s used mixed road wheels of all-steel wheels consisted of rubber wheels. This is because there was a shortage of rubber supply between 42-43. Early T-34(1941-early 1942) has all rubber road wheels, but by 42-43 some wheels had to be subsituded by all steel wheeels. By later 1943, Russian regain rubber supply, that's why later T-34/85 had rubber tires.
In fact the older Tamiya T-34/76 1942Model & 1943 Model supply both rubber and steel wheels.
    July 2004
  • From: ...Ask the other guy, he's got me zeroed-in...
Posted by gringe88 on Monday, July 19, 2004 10:03 PM
Sign - Ditto [#ditto]Sign - Ditto [#ditto]Sign - Ditto [#ditto] with him, I've got squadron/signals book, and it does say that.
====================================== -Matt
Posted by Anonymous on Tuesday, July 20, 2004 1:43 AM
They look sorta like expensive suv rims to me lol
    July 2003
Posted by diggeraone on Tuesday, July 20, 2004 1:52 AM
Also the Russains used steel wheels as replacement when the others were to chewed up and ready for replacement.You must remember that the T-34 was also design for the road and could remove there tracks to run faster on pavement.Digger
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
Posted by Anonymous on Tuesday, July 20, 2004 7:24 AM
The T-34 series could not run on the road without it's tracks. The orginal Christie design that the T-35 is based on could since it had some way of transmitting the power to the road wheels. The tracks were stored on the fenders when it was operating on the road at max speeds. As an ex-tanker changing tracks takes a lot of time and work.
All three of the T-34s have the same road wheel replaced with the same wheel. Someone had a plan for some reason.
Posted by tigerman on Tuesday, July 20, 2004 10:05 AM
That makes sense. I had the two Tamiya kits and they did supply both.
 Eric
Posted by Anonymous on Tuesday, July 20, 2004 10:17 AM
QUOTE: Originally posted by AikinutNY
*snip*
It's not just the same one but they alternate between rubber and steel. It definately looks like it was intentional in this unit and not just a replacement with what was handy.
Did steel wheel T-34s have the same trouble as the Steel wheel panthers, I.E. cracked track links?
Posted by Anonymous on Tuesday, July 20, 2004 1:28 PM
O.K. all this conversation made me want to build a T-34 with different wheels. Thanks for the replies guys it was a lot of fun!
Posted by ABARNE on Tuesday, July 20, 2004 2:14 PM
*snip*
What I remember from Squadron's book is that when they were doing a rubber/steel mix-and-match, they would typically use rubber wheels on the ends and the steel ones in the the middle for the best ride. Given that practice, it makes a certain sense that one might place an additional rubber wheel, when available, in the center position. It looks sort of balanced that way.
On the other hand, barring operational experience to the contrary, I would have thought that two rubber, two steel, one rubber would have made for a slightly better ride and simply alternating them, by placing more rubber in the front.
    July 2004
Posted by Lt. Zogg on Tuesday, July 20, 2004 2:16 PM
I just read the other day that the M1942/43 T-34s were supposed to have all steel roadwheels (due to the rubber shortages mentioned already). However, in practice it created a harmonic vibration that was damaging the tanks. The problem was solved by using rubber tired wheels on the first and last spots. I'm sure there were also field replacements where the first available wheel type was used in the needed spot.
Jeff
Posted by Anonymous on Tuesday, July 20, 2004 9:19 PM
Sign - Welcome [#welcome] Lt. Zogg
Any way, if you look at the DML Panther D box art, then you can notince that the T-34 burning has 2 different types of road wheels. Neat, huh? Just noticed that today.
Posted by tigerman on Tuesday, July 20, 2004 9:26 PM
Sign - Welcome [#welcome] Jeff to the forums.
This has turned out to be quite imformative.
 Eric
Posted by Anonymous on Tuesday, July 20, 2004 9:45 PM
Yup. Matter of fact pretty much over half the pics I have show two or three different wheels on the same tank. And Lt. Zogg hit the nail on the head in terms of the harmonic vibs.
    July 2004
Posted by Lt. Zogg on Wednesday, July 21, 2004 12:16 PM
Thanks for the welcome, guys. I'm just starting to get back into plastic modeling after a several year break. I've been lurking here for the last few weeks, and I' ve probably learned more in that time than in all my previous experience. This site is a great source of information and inspiration!
Jeff
Posted by Anonymous on Monday, July 26, 2004 6:50 PM
That is soo cool. Thanks for the conversation guys!!!
