Dragons' Firefly 5c
    November 2003
Dragons' Firefly 5c
Posted by ilikespagetti on Sunday, July 25, 2004 11:32 AM
I just got the Firefly 5c and I got around to building the turret and there's a horrble gap between the bottom peice and the main part of the turret after fillinf and sanding them i lost the little indentaion texture. I was wondering if anyone had any tips on recreating this. Thanks
I am a man, But I can change. If I have to....I guess...
    July 2004
Posted by wbill76 on Sunday, July 25, 2004 3:44 PM
Haven't built that kit but are you referring to a weld seam in that area that you lost because of the sanding? If so, I've heard of people using a slow spinning drill bit or similar tool to recreate the look but would recommend trying it out on spare plastic first to see if it's what you want.
DISCLAIMER: I've never used this particular method and am not responsible for any damage done to your kit, powertools, work area, or any other property you may have in proximity to the area if/when you attempt this method. Big Smile [:D]
    December 2003
Posted by buff on Sunday, July 25, 2004 6:13 PM
I am building that kit too, and I didn't have any problem with the turret. My problems were mostly with the transmission housing. Where on the bottom of the turret exactly? There are several of us just finishing up this kit, and Shermanfreak who knows everthing there is to know about the Sherman, so help is on the way.
On the bench: 1/32 Spit IXc
    July 2003
Posted by Dwight Ta-ala on Sunday, July 25, 2004 7:58 PM
ilikespageti,
Are you talking about the cast steel rough texture of the turret? Well, you can as wbill76 suggested LIGHTLY bounce the tip of a drill randomly about 30 degrees angle to the turret surface or press a very rough sand paper against it.
I have tried both but I suggest you try it on a piece of plastic scrap to see if you like the result or not before doing it on the model.
Good luck.
    January 2003
Posted by wipw on Sunday, July 25, 2004 9:30 PM
You might want to look up the thread Dwight did a couple of weeks ago about his Firefly. The title was something about posting pics of his Firefly. We got into a bit of a discussion about some of the fobiles of this kit. I posted one last week on my (nearly) completed Firefly and posted a bit about some of the problems I had with the running gear. I'll try and find the links and post them here.
Here's Dwight's:
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=24091
And, here's mine:
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=24296
I hope they help! Good luck with it.
Bill ========================================================== DML M4A2 Red Army ========================================================== ========================================================== -- There is a fine line between "hobby" and "mental illness". (Author unknown)
