Set your model up where you can rotate it. If you mist just from one side, any projections will act like a mask and you'll get this very subdued but annoying patterning. I mount my models on a lazy susan so that I can rotate and hit it from 360 degrees for misting.
If your airbrush is too far away, the paint will dry before being applied and it will look more like you have dust all over your vehicle or it will look sand painted. Use a lighter coat and a lightened mix of paint to give you the same effect and work like you would if you were panting a base coat. Better to do 2 or more applications than if you rushed it and over did it.
Some ar more comfortable doing it other ways, this is just mine. Good luck and lets see some pics of your finished project.
"Imagination is the dye that colors our lives"
Marcus Aurellius
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
