upper tracks to sag?
Posted by Anonymous on Saturday, July 31, 2004 2:14 PM
how do YOU get that 'sagging' look to your tank tracks on models?
I have taken to glueing the upper edge of the track to the topside of the wheels,
what do you do?
regards
Dave
Posted by Rob Gronovius on Saturday, July 31, 2004 2:19 PM
It depends. No problem using individual links but with vinyl links, I use a couple of different methods. First I try to do what you do by gluing the top down to a few road wheels. If that won't work for various reasons, I use transparent thread (used to hem trousers) to tie them down. I bought a spool of the darker colored transparent thread and it has lasted for years.
Just loop the thread between the pair road wheels and thread it through some of the natural cracks in the track (or use a needle to poke it through). Works pretty good.
Posted by Anonymous on Saturday, July 31, 2004 2:21 PM
nice idea Rob, will get some thread before next build
Smile [:)]
    July 2004
Posted by wbill76 on Saturday, July 31, 2004 5:00 PM
Not a bad idea at all Rob for the vinyl tracks. I've heard of using hairdryers and various other methods to try and induce sag but have never attempted them myself. I've carefully stretched them in the right areas to produce a little sag but nothing quite compares with using indy links in that department I'm afraid. Big Smile [:D]
Posted by Anonymous on Saturday, July 31, 2004 5:09 PM
Whoah, A hairdryer, I' would nver have thought of that does it actually work or does your model just melt?
In addition to Rob's techinque a harder yet alternate way to do it is to but pins over the tops of the tracks and insret them in the Hull of the tank its supposed to work but
I've never tried it
Posted by Spamicus on Saturday, July 31, 2004 6:19 PM
I use either the thread or the pins, if the tank has a lot of open space between the upper run of track and the fenders, like a Tiger, I go with thread. If the fenders are close the the upper run of track, like a KV I, I use the pins, obviously because the fenders help hide the pins. Both methods are easy and work very well.
Steve
Posted by Anonymous on Saturday, July 31, 2004 6:31 PM
I had to scratch build a roller bearing to get a sag on this 1/35 RC. Works pretty well without drag. I have since altered the skirt so it's hidden some more.
