thanks for the comments fellas
as for the questions, here goes :
the figs. : - from 1991 verlinden :two in a tub
- us. army airborn(operation varsity 1945) from dragon
- the german panzercrew came from the sparebox (i think tamiya )
- farmer is mainly scratchbuild on the body of a us.marine(s) from italeri
street: - spread readymade wallfiller (in a tube) over the base and when dry carved the cobblestones in it.
pavement : - cut pieces of wood in 0.8cm square glued them to the base and coated them with a watery mixture of plaster to give it texture, then a good sand and filled the spaces with whitegleu and fine sand.
lamppost : - the base is from the road sign set from tamiya and the 2 lamps are scratchbuild from plasticcard (0.5mm) and the bulb from the head of a needle(the ones that come with a shirt when you buy a new one
as fot the furniture it's all scratchbuild from wood (with the help of my fatherinlaw for giving tips for the stove and layout of the building)there's only one sutch house remaining(they going to demolish it also) not so far where i live
wallsign is from http://www.jdhodges.com/posters/categories/
roof is made from real 0.75 mm leadsheet cut in 1cm strips and bend them in a sort of a mold( send some pic. later with the jagdpanzer)
the jagdpanzer IV is from revell not to bad build but need some detailing)
and from tamiya : german motocucle b.m.w r/75 with extra detail
as for the figs. they have all(exept 2) been repositioned of arms-hands and heads. oh almost forgot : the walls from the house is from plasterboard stiped of it's cardboard (hotwater)
going to send later some more picture by request from the jagdpanzer and roofmakingdingies
LUC.
