What is the best way to make mud?
Posted by Anonymous on Wednesday, April 23, 2003 9:59 AM
Can anybody share some ideas on the best way to make mud on my armor? Some good resources would be just fine also
adws
Posted by Anonymous on Wednesday, April 23, 2003 10:19 AM
There is a very good article in the May 03 FSM. It goes pretty indepth on how to add mud to your armor. Hope this helps!
    January 2003
Posted by shermanfreak on Wednesday, April 23, 2003 10:49 AM
There are quite a few different methods to produce mud on tanks. Use the real stuff from your back yard, spackle, putty, the list goes on and on. Mix in a little simulated grass and you're on your way. Personnally I use the putty / organic method. I will mix a little putty with some Woodland Scenics grass and some brown paint, apply where necessary. Dry brushing with other earth tones after it is dry and some heavy weathering with pastel chalks and Taa Daa....mud. Like everything else it takes a little practice until you are fully satisfied, try it on an old kit until you are comfortable.
Posted by Anonymous on Saturday, April 26, 2003 7:10 PM
I use acrylic tube paint. I get it at Walmart. It's cheap and it's a good consistency. Just mix your color and gob it on thick. So far it's the best looking stuff I've found.
Jordy
Posted by Anonymous on Monday, April 28, 2003 7:53 AM
Mud...sorry, I had to. Try dirt, white glue, some water, you might need to play with the mixture, but it does work, a really thinned mix is good for tread and road wheel weathering. To set it, a dullcoat works best, maybe a touch of gloss on the contact point with the track and dirt, it makes it look wet. LOL
Hang and fire!!!!
Posted by Anonymous on Monday, April 28, 2003 1:00 PM
Well, if you want mud packed in the tracks of a tank I like to do this. Thin whatever earth tone you want to use, with some thinner. (Simple Testers model paint is fine.) and add it in to some baking soda/powder. Its important to remember to NOT thin it down to much or when it dries it want dry hard, but brittle.
The hardest part is application. For me, mud splatters are the hardest effects to render. Some times it works just to “fling” it on to your model. But the "arching" mud pattering you see on wheele wells of vehicles from mud "overspray" is nerly imposable for me to render.
I wouldn’t necessarily put any grass in it. For one reason only though. I Have worked extensively around tracked heavy equipment and light armored APC’s (M-113 to be exact.) I have never seen grassy mud get packed in the tracks. I’ve seen it get stuck up in the wheel wells but that’s about it. And the tracks dont spen fast enough and are well enough inclosed in the track housing to NOT through it. Now if you where building a 4x4 of some sort then that woudl be difrent.
BUT you never said what affect you where looking for in the mud. (packed or flung)
Also. If its for a diorama, try plaster aperies (sp). Make it thick so you can mold it like putty, but not so thick its not milky smooth. Build up your road or field or what ever scene you want and place the tank in the mud pressing down firmly. Lift it out, move it down a length and place it in again. You should affectively be making a “trough” that your tank has driven through, with the “mud” swishing out from the tracks to form ruts
Posted by Anonymous on Tuesday, June 3, 2003 4:21 PM
Get ye a cauldron and put some 1:1 water to PVA and sawdust veryfine sawdust
make the mixture relatively viscous by adding plaster of paris (small amounts!) or flour until u think it's thick enough then just have a party. (oh yeah and you shouldn't leave it too long to smear on the relevant area
Seb
