Hetzer BMM ambush scheme
Posted by Anonymous on Sunday, August 15, 2004 5:24 PM
How would one go about making the continuated circle, cloud scheme on the Hetzer? I was thinking about using a hole punch, but that is too big. also, i thought about using a die punch, but on mine, there are these pins that hold the 2 pieces together at the end, and the size i need is at the end and then restrict the paper from being moved and completing the cloud. Any help.
Posted by Anonymous on Sunday, August 15, 2004 6:35 PM
There is an article in the last AFV magazine about doing the "disk" ambush pattern.. I think they used a circle template to trace the pattern on a stencil, then cut out the parts of the stencil to be painted..
Posted by Moses on Sunday, August 15, 2004 6:45 PM
I did an ambush schemed Hetzer a while back. I have to get pics of it. I saw a pic of a Hetzer with 2 tone camp and small triangles as teh ambush scheme. I made the small triangles in different sizes using plastic card. If you have a Histerex Round Punch and Die set you could get very small circles.
"ZIM FIRST, ASK QUESTIONS LATER!!"
Posted by Anonymous on Sunday, August 15, 2004 8:22 PM
QUOTE: There is an article in the last AFV magazine about doing the "disk" ambush pattern.. I think they used a circle template to trace the pattern on a stencil, then cut out the parts of the stencil to be painted..
Is that issue 16 or 17?
Posted by Anonymous on Sunday, August 15, 2004 9:13 PM
Issue 16.. The Panther issue..
Posted by Anonymous on Sunday, August 15, 2004 11:10 PM
I thought about using a mechanical pencil eraser, which would be about the right size, as a rubber stamp. Cut the end off nice and flat, dip into a thin layer of paint and apply. At least in theory, I've not actually tried this, but it may be worth an experiment.
