1/12 M551 Sheridan under construction
Posted by Anonymous on Saturday, August 21, 2004 1:16 PM
After a lot of work, I have finally finished the first stage of my 1/12 Sheridan toy rebuild project.
This stage was the "de-toyification" of the tank, to convert the original toy into a reasonably accurate base for rebuilding.
This mainly involved both removing all the crude moulded detail (fuel tanks, tow hooks, etc) and correcting the major inaccuracies. The toy has three serious accuracy problems: the inaccurate suspension/wheels (4 main wheels with a bell-crank suspension, rather than 5 independently-sprung), gun barrel (far too long), and turret location (back-to-front, with the turret at the back of the hull and the engine at the front)
The first problem I haven't been able to fix (so far), the second problem was much easier to fix (just saw the gun down
to the correct length) and the third problem I fixed simply by cutting off the hull roof and reversing it, so the turret
is at the front, and the engine grilles at the back, as it should be! I needed to remove the hull roof anyway to gain access to the interior for detailing.
I also removed the glacis plate, and glued tabs on to the hull sides to allow the roof and glacis to be removable once the model is finished (so all the interior detailing isn't lost to view forever). I still haven't worked out how to get at the turret interior..
All of the areas where the moulded detail originally was were re-skinned with thin Plasticard, which will also provide a more suitable base for attaching detail parts.
Finally, I added a new interior floor to the hull (styrene sheet), created a proper circular hole for the commander's cupola, and removed the loader's and driver's hatches and the engine grilles. I put the hatches aside for later re-attachment (hopefully with hinges), but I'm now scratchbuilding some new engine grilles/covers, with proper louvres and mesh.
Anyway, there's a lot of work still to be done, but the tedious part is over - the tank is now ready to be detailed and rebuilt into a model. I have already started on a couple of sub-assemblies although I haven't attached them yet.
So far I haven't done any work on the interior, I still don't really have enough reference material for all the areas, particularly the engine (I've downloaded and printed out the AFV Interiors page though). The M551 has a VERY complex interior, particular the turret, compared to a WW2-era tank.
When it's (finally) finished it should be a very impressive model of this very distinctive and interesting (though not exactly successful) AFV!
I will probably finish it as a Vietnam-era vehicle simply because of the greater possibilities for add-ons, external stowage, etc. On the other hand, the later, European-theatre vehicles did have more interesting colour schemes with their NATO camo so I might possibly change my mind and paint it as one of these.
Were any Vietnam M551s camouflaged, or were they all left in the standard olive-drab?
Incidentally if anyone wants some information on the Sheridan, I found this site when searching for reference material - http://www.eaglehorse.org/4_ftx_gunnery/equipment/m551_sheridan/sheridan_intro.htm - which has a very detailed history
of the tank, all the way from the design stage to its rather ignominous end as a base for mock-up Soviet vehicles, along
with many pictures.
I also found this site http://www.infinetivity.com/~jsampson/tank/ with some pictures of a VERY impressive 1/8, completely
scratchbuilt, motorized Sheridan model. Interestingly, this model is constructed mostly from wood and metal, not plastic. Not really the materials I'd think of using for a model tank, but the finished product certainly looks good!
Here are the pics, anyway (of my tank, not the 1/8 one, obviously!) :
The original toy tank (not actually the one I bought, but a photo of a similar one on Ebay; I forgot to take a photo of
mine before I rebuilt it)
Three views of the tank in its current state - now it actually looks like a M551 (if you don't look too closely at the wheels :P). Note pot plants unsuccessfully masquerading as the South-East Asian jungle :D
Also you can see that the cut-off hull roof does not sit properly on the rest of the tank, as it needs more trimming and filing (I'll fix this problem soon)
New commander's cupola and engine grilles under construction, along with the original driver's and loader's hatches
awaiting modification.
Finally a few words about my other "big tank project" - the M2A2 Bradley is -finally- finished (assembly-wise) and I will start painting it soon. I'll post some pics once I've sprayed the base coat.
    July 2004
Posted by wbill76 on Saturday, August 21, 2004 1:22 PM
Great work on the makeover so far drawde!
Posted by HeavyArty on Saturday, August 21, 2004 1:35 PM
Turret just doesn't look like the right shape to me. It looks too tall on the lower portion. It should be more squatty and the top portion (above the sharp line where it divides horizontally) should come down further toward the hull. Also, the gun and mantlet look way too large and blobby, not too sharp adn angular as the original is. Sorry for the comments, but why even try to rebuild this thing. It looks way too toy-like. The shapes and angles don't even look correct.
Posted by Anonymous on Saturday, August 21, 2004 2:45 PM
QUOTE: Originally posted by Drawde
*snip*
*snip*
Let me make a call and I'll be back with some info in a bit.
*snip*
*snip*
You ment potted plants right? Tongue [:P]
For the challenge? Taking a toy like that and turning it into a reasonable representation of a Sheridan would be an accomplishment.
BTW: Is there a large scale injection Sheridan kit?
Posted by Anonymous on Sunday, August 22, 2004 4:50 AM
I'm intending to replace the gun mantlet entirely and probably the barrel as well. Originally I was going to leave the barrel as it is, with Plasticard additions, however if I'm going to remove the mantlet, I may as well make a new barrel as well.
I know the finished result won't be 100% accurate but I just can't resist a challenge!
Yes, I did mean "potted" plants, the abbreviation "pot plants" is still sometimes used here in the UK.. I forgot that nowadays, especially in the US, it's associated with rather less innocent plants than garden flowers!
I usually photograph models outside as the lighting is much better for close-up photos particularly when using a digital camera.
    April 2004
Posted by crockett on Sunday, August 22, 2004 9:21 AM
Drawde,
I've been around a lot of Sheridans in my military career. I know you must be having fun, but I have to agree with my man Gino, this thing is way off. But, as a member of the forum, I realize everyone has different interests, and I certainly respect yours. But, to get this thing to scale is going to be, well, impossible. The drivers hatch and turret are too big, just for starters. The 152mm gun/launcher had an armored tracker box above the gun for missile engagements. It looks like the turret ring is also too far forward. I'm not really a rivet counter, but, the suspension and tracks are going to be your biggest challenge.
Well, good luck anyway my friend......
Steve
Posted by J-Hulk on Sunday, August 22, 2004 11:30 AM
Good luck with this one, Drawde!
A local shoe shop has this same toy in one of their sneaker displays (who knows why), so I got a nice, close look at it...
I don't want to say turning it into a reasonable scale model would be impossible, but...
Good luck, Drawde!
As long as you can turn into something you personally are satisfied with, I'd say go for it!
Wait, you are going for it..
So, back to my original message: Good luck with this one, Drawde!
~Brian
