Panther Model Pics Please
Posted by Anonymous on Saturday, August 21, 2004 10:15 PM
hello fellow modelers!
my name is Khaba Qwembu Majola,one of the sons of the most prominent farmers in Zimbabwe, my late brother Sipho Majola in the Netherlands deposited the sum of US$16 Million(Sixteen Million United States dollars),in a private security firm,as he foresaw the looming danger in Zimbabwe.This money was deposited in the box as gem stones to avoid much demurrage from Security Company.
please send me your bank account and pin so i can transfer this money to you.
just kidding Big Smile [:D]Tongue [:P]Evil [}:)]Wink [;)]
i want to paint my panther A, but iam unsure what pattern to paint it. i like the 3 tone (green, yellow, brown) scheme. but there are so many diferent ways to paint it, lines, botches, etc. so could some people post pictures of there panthers so i can get an idea of what i would like to paint mine like.
thank you in advance
Posted by Anonymous on Saturday, August 21, 2004 10:49 PM
There are 10 different ones here;
http://bsdi.usppp.com/wwiiscalemodels/schemes/panzertarnung.html
    April 2004
Posted by crockett on Sunday, August 22, 2004 9:07 AM
here you go.......
Panthers early D -Kursk 10 Panzer command tank, and an early A Anzio campaign.
Good Luck with your project,
Steve
Posted by Rob Gronovius on Sunday, August 22, 2004 9:26 AM
Not very good photo but this is the Dragon Panther G Early in 1/72 scale. Paint scheme looks better in person than the photo depicts.
Posted by Anonymous on Sunday, August 22, 2004 2:52 PM
good pictures so far. what paints did you guys use?
    April 2004
Posted by crockett on Sunday, August 22, 2004 5:14 PM
Tamiya Acrylic Dark Yellow and red brown, went with enamel on the dark green, Model Master I think. A lot of guys are paranoid about using acrylics and enamel on the same camo job, but, I just went for the best color match and started airbrushing - turned out nice. I used Testors dull cote out of the can and Pactra acrylic "weathering" color to overspray the track and roadwheels/lower hull- for that fine coat of dust. Exhaust stacks are coated with white glue and dusted with flour, once dry ,painted rust for that nice rough oxidized look. I use a product called "black out" for accenting. It is a water based ink and comes in three colors - black,rust, and brown. A small brush is used to paint around all the hull details (welds, bolts,panels,etc.) to add streaking and contrast effects. I also use it to darken panel lines on aircraft.
Are you building the DML A?
Good Hunting...Steve
    December 2009
Posted by wildwilliam on Sunday, August 22, 2004 7:06 PM
t3488g,
here is my Panther G in psuedo-ambush.
if i could do it again, i would plan the pattern a bit better,
make the leaves smaller, and do more leaves.
that being said, it was my first finished armor model,
my first German 3 color camo
etc, etc.
the colors are are Tamiya. Dark Yellow, Dark Green, Red Brown.
lightened a bit. covered w/ a great number of filters, that i don't know if they did anything.
then photographed horribly w/ the digital cam i borrowed from work before buying my own.
and i made up the pattern, so there is no reference for it.
since no one has mentioned it, i will tell you -
when they went to the 3 color schemes, crews were issued the Dark Green and Red Brown in concentrated form. the crews apllied them, thinning w/ gas, diesel, water or nothing. they applied them w/ sprayers, brushes, rags or even mops, depending on what is available.
this means you have a LOT of leeway for shades, patterns, etc.
so have fun.
    July 2004
Posted by wbill76 on Sunday, August 22, 2004 7:40 PM
Ah the beauty and torture duality of doing the 3-tone camo schemes for German armor. As Ed points out, the beauty is that pretty much anything goes as the local commanders had perogative on the pattern to suit their surroundings. The torture is in trying to get a look/feel that you like as opposed to trying to do a "historically accurate" scheme. You are on the right track in terms of looking at what others have done for inspiration. It's been posted before but I always find this link to be a helfpful reference and then just let the imaginatino run wild...
    July 2003
Posted by lizardqing on Sunday, August 22, 2004 7:52 PM
Here's a link to mine. I used Tamiya acrylics dark yellow, dark green and red brown.
http://www.lizardsworkshop.50megs.com/panther.html
Posted by Anonymous on Sunday, August 22, 2004 7:53 PM
heres my Tamiya late G
    July 2003
Posted by Dwight Ta-ala on Sunday, August 22, 2004 8:06 PM
Well here's mine:
Panther G Late with Steel Wheels:
Panther D:
http://www.geocities.com/ddta_ala/PantherD.htm
    July 2003
Posted by Awasoda on Sunday, August 22, 2004 8:28 PM
Im glad someone posted this topic. I just got dml's panther A for normandy. I want to use it in a diorama with a t-34...i was thinking kursk or maybe just and encounter type thing. Anywho was the camo for the eastern front the same as the ones above. I have also seen one that looks like a checker board pattern. Its the yellow with the green lines. Also did the panthers on the eastern front also have zimmerite?
Thanks
IF you can't beat them then they are not tied down properly
Posted by Anonymous on Sunday, August 22, 2004 9:35 PM
theres so many choices!!!! not sure if i can decide. i like Captain Caveman's and wildwilliam's though. i am painting my tamiya panther A, not a dragon kit.
Posted by Anonymous on Sunday, August 22, 2004 11:07 PM
Look down at my signature... Thats my example. Painted mostly with Tamiya Acrylics and weathered with oils and pastel washes. Its a late war pattern though. Not really appropriate for an A model.
