Italeri 1/35 M60 Blazer.. Uhmm anyone have problems with crooked molds?
Posted by Anonymous on Sunday, August 22, 2004 9:27 AM
Building this Italeri M60 Blazer, the detail is nice.. the mold of the bottom portion of the hull ie: (suspension, wheel mounts, etc etc) is off by about 1/16th to 1/8th of an inch.. so that nothing lines up right.. Banged Head [banghead]
Any suggestions other than just building it and hope for the best?
Posted by Rob Gronovius on Sunday, August 22, 2004 9:32 AM
Go to Testors.com and request a replacement part.
Posted by Rob Gronovius on Sunday, August 22, 2004 9:40 AM
I took a look at my Revell of Germany M60A3 (basically the same kit as your Blazer). The hull is fine on mine. Are you talking about the way the road wheel mounting arms are slightly offset from right side to left side?
If so, the actual tank is like that because the suspension system uses torsion bars that go through the entire hull. One bar comes in from the right, the other from the left so the road wheel arm mounts are offset with the left side mounts slight forward of the right side mounts.
This is a common feature on US armored vehicles since the M18 Hellcat, M24 Chaffee, M26 Pershing going all the way to the M2A3 Bradley and M1A2SEP Abrams.
Posted by Anonymous on Sunday, August 22, 2004 10:19 AM
AHhhhhhhhhhhhhhhhhhhhhh.... Ok, that makes complete sense! Yes, this is my first modern armor vehicle.... Heh... Great now all the guys at Testors.com probably think I am a looney tune probably.. hahahah
Thank you very much for the information sir! You have been most helpful...
