mud
    November 2003
mud
Posted by blitzer on Monday, August 30, 2004 3:53 PM
I know this is the first time this subject was ever mentioned ,(yeah right) but I want to know every one makes their mud on tanks. What ever any one can tell me appreciated.
thanks,
Levi
yesterday was my b-day (17Party [party])if any one wants to you know, give me a new airbrushMischief [:-,]Laugh [(-D] just kidding just kidding thanks every one for your help!
    April 2004
Posted by crockett on Monday, August 30, 2004 4:38 PM
Go out to the garden, dig a spoonful of dirt, go back to your bench, apply it to your AFV,seal with the medium of your choice. badda boom badda bing!
Posted by JWest21 on Monday, August 30, 2004 5:07 PM
I mix some sand (from the Rustall kit) with Elmers glue and Tamiya paint (buff, dark earth, or whatever color your aiming for) on a [iece of cardboard and stipple it on the tank with an old stiff brush. When it dries, I give a wash of browns and thent a shot of MM Acrylic flat to take away the satin finish.
Jason "There is a very fine line between "hobby" and "mental illness." -D. Barry
Posted by Anonymous on Monday, August 30, 2004 5:12 PM
Try thinning Tamiya putty with liquid glue (thin stuff is best) and mix with coffee grounds and some static grass. Stipple onto the vehicle and add more coffee grounds in a random pattern. The glue/putty mix makes it stay on the kit.
    October 2003
Posted by rebelreenactor on Monday, August 30, 2004 5:34 PM
I made some out of celluclay. Not the best but it can be done to look really good. Just have to make sure and use the right color.
John
Posted by Anonymous on Monday, August 30, 2004 8:32 PM
I mix flour, white glue whatever color floats my boat, and static grass together then apply it onto the model with anything really...
Good luck
    November 2003
Posted by blitzer on Monday, August 30, 2004 9:38 PM
thanks alot every one
    July 2003
Posted by Awasoda on Tuesday, August 31, 2004 8:43 AM
Well happy birhday...mine was yesturday too (16). WEll what i do is get some spackling past mix some brown paint in it, sand and maybe some clippings of hair like substance. Then i paint it on. When its dry i drybrush it with earth tones and add future to it to make it look wet. They only thing is it wont come off so do it right hte first time.
IF you can't beat them then they are not tied down properly
Posted by ABARNE on Tuesday, August 31, 2004 1:57 PM
Another technique that I've used is to grind artists pastels (basically colored chalk) into a fine powder, mix it with some flat acrylic to act as a binder, and stick it to the model. You can put it on reasonably heavy, although for a really thick build-up, using a few light coats is better to help alleviate cracking problems.
About your air-brush, I'm guessing that you're on a tighter budget. I recently picked up an inexpensive Paasche single-action unit for about twenty bucks. I think they were able to make it so inexpensive by using a molded plastic body rather than machine aluminum. I've done some clear coating with it, and it seems to be a fine unit.
Posted by Anonymous on Tuesday, August 31, 2004 3:25 PM
My little mixture I like to use is this. Plaster of paris, Cheap acrylic paints from the craft store, pastels, a bit of white glue and some real dirt (sifted fine) and herbs thrown in for good measure. It usually dries light colored so I can use oil paints to stain it light and dark brown to make wet or dry mud.
Posted by Anonymous on Tuesday, August 31, 2004 3:38 PM
I use what ever works:
1 Good ol' ground up dirt (as mentioned) microwaved to kill the little crawlies and molds, mixed with white glue (wet mud), with acrylic paint mixed to match its dry color (dried mud), sprinkled over a coat of the same acrylic paint (dried, compacted or dusted soil).
2 A mixture of putty and some sort of grit.
3 Pastels (as mentioned), which can also be 'powdered' or brushed on.
I love messy, dirty tanks (just like they REALLY look). Light weathering is great for 'in garrison', 'on parade' or New into battle, but not for a well used (even a couple of days out) vehicle. Unfortunately, the current 'doctrine' is for weathering that's so light it makes the vehicle look as if it's in a museum or something. I DO do light weathering when I want to show off a cool camo scheme or something, but usually LOVE HEAVY, VERY HEAVY weathering.
Ron
Posted by ponch on Wednesday, September 1, 2004 10:49 AM
I just mix pastel powder with white glue to form a sticky paste, and apply it directly to the AFV. If you thin the white glue with water, then you can pick up this 'muddy water' with the bristles of an old toothbrush and flicker it on the model for that splashed look. Once I'm happy with the results I seal everything with a coat of clear flat.
