for the snow armydog ; paint the undergroung matt white , then make a mixture of bakingsoda+water+white glue (i used woodglue but i guess you known it better as elmers glue) then just brush it over the ground. just need a bit more experiment with the ratio water/gleu (it was a bit thick
) in real the snow sparkel a bit ,don't show in the pic. so mush) if you want more frozen snow just brush wen it dry another layer of gleu/water on top of it.
frostygirl the kit comes nicely together only needed a bit of filling between the top and lower bodyhalves and a bit of detailing (found not a lot of pic.on the net of this one
just placed the machinegun on a pole ofcentre the coppula and repositioned the ammobox, and be carefull with the tracks (there are no extratracklinks
