I do pretty much the same thing except without a jig. I just use the lines on my cutting mat to keep the smaller sections together. I build mine in 7-10 link sections and let them partially set up on the side. I use Tamiya Extra Thin Cement exlusively on plastic individual track links.
I always start at the sprocket and try to build a section that is two or three links longer than needed to reach around. This section I will only allow to set up for maybe ten minutes...just long enough that it won't pull apart easily, but not so long that it doesn't want to bend easily.
Once the sprocket section is formed, I'll work my way back (usaully bottom first, then top) until I can build an idler section that reaches both ends. I'll attach the lower end first - since this should be kept taught - and then wrap the section around to the top. With German armor a link or two longer than tight is just about perfect. Attach the top section together, let it sit for 5 or 10 minutes, then you can tweek the top run to form the level of sag you want.
I actually do not glue the track to the wheels, sprocket, or idler at all. I leave it loose and find that if there is a stubborn spot where the track just won't stay down, you can tack it later.
Enjoy your modeling...
