Try using stretched sprue. While it is stretching, wrap it wround something the same diameter as the wheel you need. Then cut it so it has formed a ring. Remove the old outer wheel portion of the steering wheel and replace with the thinner stretched sprue ring.
It may take some trial and error to get the thickness and diameter right but the raw materials are free.
