QUOTE: Originally posted by SkippyOU110
Okay, next round of questions. When should I start painting? Should I do some assembly first and then paint? If so about how much assembly should i do? Sorry for all the questions I just want to get this right. Thanks again!!
It depends on whether you are airbrushing or handpainting or both. Generally speaking, I will get the hull together with the details built minus the tools and then AB the hull with the pre-shading and basecoat+camo if applicable, then add the wheels and tracks after, with the tools handpainted and added last.
There's no one magic way of doing it and each kit has to be given some consideration as to parts layout and how many nooks/crannies will be produced if you build it all first or build some, paint, build more, hand detail, etc.
