Painting Tamiya's Mid prod Tiger with Seperate Track Links
Posted by Anonymous on Monday, September 20, 2004 10:30 PM
Hi All !
I have nearly completed the Mid Prod. Tiger with Seperate Track Links.
My question is, do I put the track links on before I paint the Tiger overall ?
If so, what colour do I paint the links ?
Do I paint the track links and road wheels a darker colour ?
Please help, I am eager for answers.
    July 2004
Posted by wbill76 on Monday, September 20, 2004 10:35 PM
Two schools of thought here for the most part:
1) Build the tracks around the wheels and remove them after they've set up enough to hold their form and paint off the vehicle.
2) Paint them as indy links first and assemble after hull painting, then weather in place as needed.
Either way, I'd recommend you paint the hull first and then add the tracks last. You will have considerable difficulty reaching the top run of tracks if you try to paint them already on the vehicle as it's a pretty tight space to begin with.
The actual color of the links depends on what you want to do with them. I had been using MM Steel as a basecoat with alternating washes of thinned Gunmetal and Rust to simulate worn tracks but I've since changed over to using MM non-buffing Burnt Iron metalizer and drybrushing with MM Steel.
Lots of options available to you depending on the finish you want. Big Smile [:D]
Posted by JWest21 on Monday, September 20, 2004 10:43 PM
I used Bill's school of thought #2- painted first. Then I glue them together, and finally wash and dry-brush
Jason "There is a very fine line between "hobby" and "mental illness." -D. Barry
Posted by JWest21 on Monday, September 20, 2004 10:44 PM
Oh, and for the color, I usually paint my a rusty color, liberally washed with browns and lightly drybrush some steel
