My T-34 Diorama
    July 2003
My T-34 Diorama
Posted by Awasoda on Tuesday, October 5, 2004 3:39 PM
This diorama depicts a squad of russian tanker troops crossing a road somewhere in Russia in the fall of 1942 while taking fire from a enemy patrol in the distance.
IF you can't beat them then they are not tied down properly
Posted by Anonymous on Tuesday, October 5, 2004 4:32 PM
That is one tantalizeing T-34, but i must know how you did such excellent ground work?
The short grass and dirt look excellent, and I was hopein maybe you could share some secrets of the groundwork! cause thats just plain hot.
Noice Diorama.
Posted by JWest21 on Tuesday, October 5, 2004 4:51 PM
Excellent job. AFD beat me to the question. I am going to be attempting a couple of dios soon, so anything you share would be a great help!!
Jason "There is a very fine line between "hobby" and "mental illness." -D. Barry
Posted by tigerman on Tuesday, October 5, 2004 5:01 PM
Very cool concept. Thanks for sharing.
 Eric
    July 2003
Posted by Dwight Ta-ala on Tuesday, October 5, 2004 6:32 PM
Excellent diorama. Good concept and good work on the tank. Great work overall.
Posted by Anonymous on Tuesday, October 5, 2004 8:10 PM
Excellent job all the way around Abe!!!!
You can almost hear the gun fire.
Posted by Anonymous on Tuesday, October 5, 2004 11:09 PM
I like it a lot! Like the above posts... please share the wealth! (of how-to on the ground work!)
    July 2003
Posted by zokissima on Wednesday, October 6, 2004 12:07 PM
Very nice work. Even though the base doesn't seem to be that large, the dio is very balanced overall.
    July 2003
Posted by Awasoda on Wednesday, October 6, 2004 3:36 PM
Thank you all very much.
Firstly,
The groundwork was made using blue insulation foam. i used this to build up the base. I carved it to the shape i wanted and glued it down using elmers wood glue. Next i apllied sculptamodl with a little bit of dark kahki paint mixed it. While this was still wet i addd the groundwork such as the dirt(woodland senics railroad tallas and gravel). When this was wet i made my impressions for the tracks and foot prints. Then after everyhitng was dry i applie a weathering mixture whihc was jsut thinned accrylic(so it wouldnt eat the foam) dark akhki paint. I waited overnight for this to dry then dry brushed with earth tones. I also used powders and scrubbed them into the groundwork too. This is good for shadding and burnt areas. Oh by the way the trench was used by removing the portective seal form the foam and dripping solvent based glue onto the foam. The grass was applied by using woodland senic staic grass. I spread on the base diluted glue (3 parts white glue/1 part water). on top of this i applied the grass. PUsh down and wati an hour for it to dry, then blow off the excess. Then i clumped together the field grass (woodland senics) together and dipped it in super glue (it holds and dries better than the white glue) and applied it to the base.
I think thats all. oh yea and it you rub a ballon on your head and then hold it near the grass it will kinda stnad up.
