Question on shell color of Late Panther
    December 2003
Posted by spector822002 on Monday, October 11, 2004 10:46 AM
I always see these painted a brass color in most models , but it was brought to my attention that due to brass shortages by wars end , this may not have been the actual metal used . It was supposedly a steel with a special coating on the outside to limit shell exspansion from the heat of fire . Is this true and what color was the coating , I painted mine light green ,but am going to change this if it is incorrect !
    April 2004
Posted by crockett on Monday, October 11, 2004 11:29 AM
According to the Osprey reference on the Panther, all late 7.5cm rounds should be steel cased. Paint them steel.
Posted by Anonymous on Monday, October 11, 2004 1:26 PM
That's not exactly right.. The shells were steel cased, but were also brass plated. So the "brass" effect would be more accurate....Wink [;)]
Posted by Anonymous on Monday, October 11, 2004 3:44 PM
There are several variations of late war shell casings. The steel casings were Parkerized to prevent them from rusting and to keep them from sticking to the insides of the breech after firing. The common color of this Parkerization, (at least in the images I have), is a light yellow-green, sort of a "Key-Lime Pie" color, for lack of a better term, although there were apparently other colors as well. There were also brass and copper plated rounds, which were made of steel, but covered with a thin electroplated coating of brass or copper.
    April 2004
Posted by crockett on Monday, October 11, 2004 3:44 PM
HMM,
So the late war shortage of brass meant they just plated the casings?, the photo I'm looking at in the reference (Osprey) sure look like steel casings. It may be the black and white effect from these old pics. Thanks for the correction.
Steve
Posted by Anonymous on Monday, October 11, 2004 3:54 PM
Crockett, I have "steel" colored casings in artwork too, but no actual color photos. It is my understanding that bare steel casings would stick to the bore due to the expansion of the casing during firing, hence the need for the coatings. Does someone have an actual photo of a bare steel casing or have first-hand knowledge of this? I am suspecting that the bare steel colored casings I am seeing in the artwork may be a misunderstanding of the term "steel casing" by the artists, but I may be wrong. I am not sure about this.
    March 2004
Posted by Mikeym_us on Monday, October 11, 2004 4:03 PM
they may have used a method to use a synthetic nonstick subtance in the manufacture of the shells.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    December 2003
Posted by spector822002 on Monday, October 11, 2004 4:27 PM
well here is a pic of my painted shells , its so hard to tell from black and white photos .
    July 2003
Posted by Awasoda on Monday, October 11, 2004 8:24 PM
Hey spector did you know you can see the tanker flying out of the tank in your pic?
IF you can't beat them then they are not tied down properly
Posted by Anonymous on Tuesday, October 12, 2004 12:21 AM
When you consider how many book illustrators depict large-bore German ammo as having steel color casings, that it must be a correct color too. There must be some other kind of transparent treatment applied to the steel that left it natural colored. I just don't know. But I do have references for light green Parkerized steel, black Parkerized steel, ordinary brass, brass and copper plated steel. I thought I saw a color photo once of a Tiger with what might be a steel round sitting upright on the turret, but I don't remember where. Sorry, there is just too much minutiae to keep track of it all.
    March 2004
Posted by Mikeym_us on Wednesday, October 13, 2004 4:02 AM
as I said before on a previous post in this thread they may have used a non stick lubricant to keep the shells from sticking maybe some enterprising crewman used gun oil on the shell. it isnt slippery but it kept things in the guns from sticking together in fact when cleaning your personal firearms the manufactures suggest applying oil to the breach of the barrel so that your ammunition doesnt stick to it and jam the weapon.
