I think I screwed up my Firefly....
Posted by Anonymous on Friday, October 15, 2004 12:54 PM
Has anyone else run into this.... why are the drive sprockets on my Dragon Firefly (new release) stickin' out about a half inch from the hull? It looks like the shaft on the sprocket hub (part V29) needs to be cut off, the directions don't show this. I pulled out an old Dragon M4A4 off the shelf and those directions do show cutting off some of that shaft. Did I screw up or are the directions wrong? Next question is do I cut off the shaft or is there something I'm missing?
Thanks
JeffEight Ball [8]
    September 2004
Posted by Jeff Gunn on Friday, October 15, 2004 1:05 PM
Jeff have a look through the Sheman GB there might be something in there:
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=11560
its a long shot but you never know
JG Per Ardua
Posted by djmodels1999 on Friday, October 15, 2004 1:26 PM
Maybe Dwight will be able to help you...
    January 2003
Posted by wipw on Friday, October 15, 2004 2:24 PM
Jeff, you are absoluetly right. They got the idler wrong too. If you build it per the instructions, the idlers will be too high and the track won't fit under the sponsons. Check out Dwights thread from a couple of months ago. We got into a bit of a discussion about the. (Swap the ilder mounts side for side on the hull from what the instructions show and you'll be closer.)
Bill ========================================================== DML M4A2 Red Army ========================================================== ========================================================== -- There is a fine line between "hobby" and "mental illness". (Author unknown)
    December 2003
Posted by buff on Friday, October 15, 2004 7:13 PM
Just to make things even more confusing, I built my idlers as per the instructions, and they fit correctly! I did have to cut the shafts on the sprockets to make them fit properly, though.
On the bench: 1/32 Spit IXc
Posted by Anonymous on Saturday, October 16, 2004 6:18 AM
Thanks Guys,,,,
I cut about an eighth of an inch off of the shaft as recommended and that did the trick. I'm alittle disappointed with the instructions on this kit as I think they are the worst I've run into in awhile. Thanks to all for the help.
Happy Modeling,
JeffEight Ball [8]
Posted by Anonymous on Saturday, October 16, 2004 8:16 AM
Provide some photos please. I would love to build that kit, but I hate the trial by fire.
G
    December 2003
Posted by buff on Saturday, October 16, 2004 5:22 PM
QUOTE: I'm alittle disappointed with the instructions on this kit as I think they are the worst I've run into in awhile.
Ahh, Dragon instructions. Dont'cha just love'em??
    January 2003
Posted by wipw on Monday, October 18, 2004 9:49 AM
The ones for the new (3rd release) of the Firefly are particularly bad. Dragon has taken the instruction sheet from the 2nd (1st??) release and tried to update it for the 3rd release. There were many parts retooled for the new release, but often, the old part numbers are called out. It's really confusing. If you seem to be missing a part, look for the same number on a different sprue. As I recall, many of them are on sprue V. Also, there are some parts that mount on the side of the hull behind the bolsters that aren't even mentioned in the instructions. They change the mounting slots for the bolsters to round holes. They aren't too hard to figure out, if you know they are there.
One other "gotcha" is the way they show the bolt strip between the lower hull front and the transmission cover. It should be relatively flush with both of them. Every Firefly model I've seen done with this kit, including mine, have it at an angle, sloped between the two pieces. I think it results from the piece being drawn basically backwards in the instructions. I'll post a couple of pictures of how one should look and how mine came out. Good luck.
    January 2003
Posted by wipw on Monday, October 18, 2004 10:02 AM
Here are the pics I was talking about. The first is of the Formations Firefly upgrade kit for the DML Firefly. I didn't get one of these kits, but wish I had. I have a 2nd edition kit that I might get it for. (Make sure you click on the picture to enlarge it.)
You can see in this one what I meant about the bolt strip. It's a bit overlit, but the strip shows up pretty well.
And here is another shot after painting.
Posted by Anonymous on Tuesday, October 19, 2004 7:20 PM
Thanks for the help fellas... I am so frustrated by this kit that I had to put it down. I have built the Dragon Panther series and had no trouble with those link to link tracks. This is my first go at their Sherman tracks and they are just awful, or maybe I'm gettin' old and just don't have the patience.I routinely use RHPS tracks with no problems, maybe I'll try those-once I get over the urge to throw it against the wall.
Happy Modeling...
Jeff [8
    January 2003
Posted by wipw on Wednesday, October 20, 2004 8:30 AM
Jeff, I gave up and used Friuls on mine. They worked great and look good, too. I was worried that they would sag too much for an allied tank because of their weight, but that wasn't the case. Robert's advice on them was that once I got them aligned the way I wanted them, to super glue the lengths together. I tried that on a limited basis but still gave up and went with the Friuls. If you look at the inside of the DML edge conectors, you will notice that the holes are different sizes (just slightly) and aren't aligned perfectly with each other. That probably has a lot to do with why they work so poorly.
Good luck.
