Zimm question for Moses
Posted by JWest21 on Saturday, October 16, 2004 5:44 PM
Ok, I was in the local hobby shop and saw some Tamiya Polyester putty and Dragon's Panther A with the aluminum barrel, so I broke down and bought both. I know you use that putty, so I have a few questions. 1) The directions are all in Japanese, so what ratio do you mix the hardener and the putty. I assume not much hardener is needed, since they give you a huge tube of the putty and an itty bitty hardener container. 2.) I assume you spead it on real thin with Zimm tools or something like a small spatula. How much area do you work with? and 3.) I am doing the simple tile pattern to start, but do you treat the tool you use to scribe the tile lines with anything to prevent the putty from sticking, do you wait a little for the putty to firm up or scribe right away and finally am I missing anything. Can you tell this is a big step for me and I am a little nervous??Shy [8)]
Jason "There is a very fine line between "hobby" and "mental illness." -D. Barry
Posted by Moses on Saturday, October 16, 2004 5:56 PM
Ok JWest, I can answer your questions very easily. I am going to email you a html file that I worked on showing step by step on how to do it. It isn't completed yet, but will be enough to show you how it is done bud.
Cheers
Mo
"ZIM FIRST, ASK QUESTIONS LATER!!"
Posted by Moses on Saturday, October 16, 2004 6:03 PM
Ok email sent Jason.
Cheers
Mo
Posted by JWest21 on Saturday, October 16, 2004 6:36 PM
Thanks Moses. I am doing the simple horizontal tile pattern. If all goes well, I will try something more difficult (always wanted to do a late Tiger)
