need help
    May 2003
need help
Posted by nsclcctl on Tuesday, October 19, 2004 8:32 AM
I confess, I like things that fly and shoot other things that fly out of the sky. I love Dauntless and Corsairs and avengers. However, I need a break so I picked up a Tamiya sherman. HELP!!!!!!!!!!! Where do I start? With planes, I do cockpit first, paint it and place it in the fuselage. I seal up the cockpit and do all my overall paint shcmes with an airbrush. I am looking at this tangled mess of sprues and wondering how do I start? Please help me with a brief step by syep to get me going. Do I build the enire tank and then paint and weather and then add on all the little tools and goodies and so forth? Also, with the figures, Do you prime them first to improve the overall paint success?
Finally, what is Tamiya XF62?
Posted by Anonymous on Tuesday, October 19, 2004 10:01 AM
Here is how I do a Sherman:
First I put on a light coat of OD on the wheels and Bogie parts and assemble them, the black for the rubber can be done after assembly.
After that i build the lower hull, uper hull and turret as seperate sub-assemblys and hit them with a layer of OD. As for the pioneer tools, you can add them right away using tiny drops of glue and then slip paper between them and the vehicle to paint them after spraying the OD or you can leave them off paint them seperate and attach after basecoating. I prefer the first method.
Now I combine the bogie assemblys (6 of 'em) and the lower and upper hulls into the complete hull.
At this point there should be a hull assembly and turret assembly.
I then do the final coat(s) of OD, paint the rubber part of the road wheels and paint/add the tools, Tracks are painted and added and weathering is done.
I don't prime figures but it seems most people do.
Tamiya XF-62 is one of their flat paints.
    July 2003
Posted by diggeraone on Tuesday, October 19, 2004 11:04 AM
Like Claymore I do basicly the same thing except the painting.I put together the subpension and the hull together,bogies sprockets everything without painting them.After this has been done then I go for the turret and gun.I leave out the machine guns till nearly last after I have sprayed paint the completed model of subpension,hull and turret.The tracks I do last and hand paint them to what I want under field condistions.The black rubber on the bogies get painted by hand after I have sprayed painted the the rest.It is easyer to do this way and keeps you from having to touch up in case you paint a bogie a different color by mistake.Then after all has been put together and spray painted,sub,hull,turret,tracks and all the little thing that go with it:like shovels axes and cables.Then take your time and hand paint and weather details that you want on this beast.Add tracks and decals weather them to match and you are done.Then set back and enjoy your handy work.Digger
The colors you want to use on a project like this are:OD green ,rust ,steel,ft.black,dk brown ,tan and sliver.Most of your tans and browns are used for weathering.As far as painting tools I would put them on the hull and spray them the same color as the tank and dry brush highlights of steel on them to show wear.Most tools were paint in od green for protection from the elements.Your tracks are basicly steel and black with a series of washes done with rust as a dry brush and tans-browns for drit.Feul spills and greese is done with a ft black wash.You can use the color rubber for greese and apply around the bogies and subpension areas followed by a tan-brown wash to show drit.
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
