Cheers guys.....some answers
The Hull of the T-44 was all new....it was wedged shaped with torson bars,,infact the T-54 hull is (almost) identical in shape...some size differances but not much,,,,
the production T-44 engine decks were differant but in this uprade type, it is very similar to the T-54A
The production type had T-34 type wheels but with differing spacings to the T54A...in the first upgrade these were replaced with the later style starfish wheels (some photos seem to show a diffiering wheel spacing lay-out....but not sure yet if only test vechs)...in this second factory uprade to the T-44, the wheels were changed due to the later engine and gearbox pack being designed for the t-54 type drive package, tracks and wheels...it is then the (due to the 'track' being wider) they had to change all the fenders and stowage,,,as seen on the model...
The turret was a little lower than the T-34/85 as well as longer, there is also a bulge on the left side to get more space in the loaders area...all 85mm types used the d-10 cannon....this second upgrade type recived early IR signts as per the T-54A
I did one of the 122mm test T-44s a while back...these were based on production tanks, so all the early features are on this one below...freaky big gun !!!!
[img.nr] http://smallshopeu.com/KVII%20%201940%20pics/Untitled-116.jpg [/img.nr]
[img.nr] http://smallshopeu.com/KVII%20%201940%20pics/Untitled-1112.jpg [/img.nr]
(In my web page gallery you can see the production style engine deck and compaire)
More pics here
http://smallshopeu.com/photo__T_44.htm
The AA kit is great...but maype the wheels could be replaced with a set of dragon ones ...wheels are hell in resin that size and concdering the shape and thin central section...I cannot blame AA for that....nice kit...if need be you can use a metal barrel...one for a SU85 is the correct type...I used the kit one with a new end cover rolled from brass/....I used as said a resin T-54 engine and 'educated guessed' the rest...it was however wired up right and that is all you can really see anyway :)
So...again thanks foor the comments guys...glad you like the T-44...I do...funky looking thing :)
AJ
