hello there, well here is my most recent model, and I had a great time building it! Its the first time I've done pe, indy links, and also the first time I've had the courage to mess up all that hard work with a wash. I had to touch up some spots after the wash stripped a little paint, but nothing too bad. I think the green colour may be a little bit too light, but overall I'm pretty happy with the end result. Although looking at the antenna, I think its too thick. Maybe I'll fix it later.
I'd have to say that if anyone out there has felt intimidated by dragon's indy links, and also pe, this is a good kit to try, as I found it way easier than I thought, just a little bit tedious at times... and painful, that one time I sliced my thumb trimming the links! as for the pe, theres just a bit, but you can try using it and if it doesnt work out, theres still the plastic parts to use.
so, here it is, and please, let me know what you think! next up will be the russian M4A2.
