QUOTE: Originally posted by Panzerjager II
Resin is simple to use after some practice, but it take a little getting used to. I started out with the "starter set" from Micro-Mark and have never regreted it. It has been very useful. As for the vinyl tires, I have found that you can get a real nice "Used" look if you rough them up with fine sand paper/steel wool and then just weather them as you would normaly. By the way, how is the rest of the kit? I have been thinking about getting one myself.
I do the same thing but usually as a by-product of having to remove the seam that always runs down the middle!
If you're worried about the vinyl tires taking enamel paint, just wash them with a mild soap and rinse thoroughly, let dry, and any mold release agent still on them will be removed and you shouldn't have any issues. If you also do the roughing up with some fine grit sandpaper, that raises the "tooth" of the surface texture as well, making the paint even more likely to adhere well.
HTH.
