There was an article in FSM about building a P47. The builder turned a bunch of brass rod or wire to make the gun ammo. Used a dremel and a file. A Herculean task at best, and not for the faint of heart,but I started thinking about it and if you were only making a short length or had it only going from the breech to the ammo can you would only have to turn a few that could be seen and the rest would be under the folds of the ammo belt in the can.
I tried this with a length of thin brass rod and it worked pretty well. Keep the speed low and use a jewlers file. I made one round about every 30 seconds. I got cockey on a few and actually hit the file along a length of rod. I then snipped at the indent and the ends. This allowed me to make two rounds in 30 seconds. I used a cut off wheel rather than snips so it didn't taper the cuts. Making a flat end good for spent shells, taper it with some sandpaper or on the file and you have the bullet. In the grand scheme of things it really didn't take all that long. Just tedious. Its a good "waiting for paint to dry "project. Now that I know it is feasable, I have to make a bunch of spent shells for a flak gun diorama. Its just screaming for the shells. A dab of flat black paint on the ends and it becomes a spent casing. And its cheaper pocket wise than a resin,PE or detail kit. Its just time expensive. And I can make any caliber shell I want.
You really don't even have to go all that far on the detail. 1/35 is about looking at someone from 20' away. So what does a .50 shell look like from 20' away?
"Imagination is the dye that colors our lives"
Marcus Aurellius
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
